If I have an arbiter that has a 16 bit valid input for 16 clients, How do I randomize such that only one bit is high at a time? This is not a system requirement, I just want a test that does this. I haven’t attempted this with a compiler but I was thinking:
class transaction;
bit [15:0] req_valid;
constraint req_order;
typedef enum{one = 16'h1, two = 16'h2, three = 16'h4,...., 16'h8000} Inputs;
program test(intf interface);
environment env;
Inputs oneHigh;
env = new();
constraint transaction:: req_order {req_valid inside {oneHigh};
endprogram
Will this work? Any better ideas? What if I want to request to also go in a particular order from the enum?
$onehot(expression) returns `true (bit 1’b1) if only one bit of the expression is high.
constraint transaction:: req_order {$onehot(req_valid)};
Ben Cohen http://www.systemverilog.us/ben@systemverilog.us
