What is the correct way to pass linked C library to the simulator for the C routines to access the C functions defined in the linked library?
For example, this C file has the proper header include <mylibrary.h> and runs fine outside of simulator:
gcc cside_api.c -lmylibrary -o runme.exe
./runme.exe // access to FUNCTION_A() defined in mylibrary works fine
However, when the same c file is used in simulation via DPI, it has issues accessing this same function when the linked library is specified as c compiler flag using.
vlog -sv -dpiheader dpiheader.h hdl_top.sv cside_api.c -ccflags “-lmylibrary” // mylibrary contains the implementation of FUNCTION_A
The error message is as follows when sim is run:
** Fatat: Undefined function ‘FUNCTION_A’ introduced from ‘dpi_30434/linuxpe_gcc-4.4.7/vsim_auto_compile.so’ is being called. Exiting …
Is --ccflags as shown above the correct way to specify a linked library to sim? Am I missing additional steps?
Thank you in advance for your help!
