I am trying to generalize an existing interface to reuse its API. This interface have to call task in module using hierarchical path.
The FPGA vendors instantiates a BFM that has to be accessed through hierarchical path from the top, like this:
tb.zynq_sys.layer1.ps7.inst.task_name(0);
Those calls can’t be made from class code inside a package (because hierarchical paths), so I created an interface in the top that is a wrapper to those task calls:
interface cpu_if;
task task_name(input[31:0] reset_ctrl);
tb.zynq_sys.layer1.ps7.inst.task_name(reset_ctrl);
endtask : task_name
endinterface
(Of course, there are multiple task in the interface)
With that interface instantiate in the top, I can now give an handle to the interface to the object code:
cpu_if zcpu();
t = top_string_factory[test_index].createTest(zcpu);
All the test code is reusable and everything is wonderful. Now I want to make the interface reusable. The only problem is the multiple hierarchical path present in the interface. I am trying to put that as a parameter. For example:
interface cpu_if(pointer_to_module bfm);
bfm.task_name(reset_ctrl);
endtask : task_name
endinterface
cpu_if zcpu(tb.zynq_sys.layer1.ps7.inst);
Of course, a pointer_to_module doesn’t exist. I am trying to use anything cleaner than an define followed by an include file. I looked at bind, but as far as I understand, bind would create an instance of the interface inside the BFM. Replacing all the instance referring to zcpu with the hierarchical path to the bound instance in the BFM would be dirtier than the initial problem.
Is there a clean way of doing this?
Thank you,
jf
