How to override uvm_config_db from extended class?
I have a base test in that I have set default config values. I created another test extended from base test and now I want to override uvm_config_db from extended test.
In base test build_phase I have done set uvm_config_db for cfg_num[`num] that is default configuration.
In Build_phase of extended test I tried to override set uvm_config_db but when I do that getting a Fatal Error which says :
UVM_FATAL uvm_test_top.env.env_num[0].xmtr_agent [build_phase] A agent_configuration object provided to constructor is not valid for class svt_xmtr_agent. Update the configuration based on prior Warning messages.
Here is the code :
class test extends uvm_test;
Env env[`num];
top_env t_env;
config cfg_num[`num];
config cfg;
super.build(phase);
t_env=top_env::type_id::create("t_env",this);
for (int i=0; i<`num;i++) begin
cfg_num[i]=config::type_id::create($sformat("cfg_num[%0d]",i));
cfg_num[i].passive_cfg.intf_type="ABC";
cfg_num[i].t_m_init=10;
cfg_num[i].t_s_init=10;
uvm_config_db#(config)::set(this,$sformat("env.env_num[%0d]",i),$sformat("cfg"),this.cfg_num[i]);
env.env_num[i]=Env::type_id::create($sformat("env.env_num[%0d]",i),this);
end //forloop
uvm_config_db#(config)::set(this,"*","cfg",this.cfg_num[0]);
class test_ext extends test;
super.build(phase);
for(int i=0;i<1;i++)begin
cfg_num[i].passive_cfg.intf_type="CDE";
cfg_num[i].t_m_init=100;
cfg_num[i].t_s_init=100;
endtask;
Please anyone help me on this.
Manish.
In reply to ms_1202:
Can you please share the agent code, as the error message is getting generated from the agent class.
Hi Sharat,
The problem is that agent code is encrypted I can’t see that code.
in base test some configuration is done and set with uvm_config_db. now in drived test I am calling super.build_phase and making some change in configuration and doing again uvm_config_db same as it was done in base test case. There I am getting this error. If I comment out this forloop in drived test then it is not giving any fatal error.
Can we do again uvm_config_db set when it is already done in base test build phase ?
Regards,
Manish.
There is no problem in doing a uvm_config_db set again. I think the issue might be with the values of the configuration that you are setting from the derived class.
You don’t need to set it again in derived class as while setting the cfg_num through uvm_config_db::set in base test passes the handle of the cfg_num type object.Thus assigning it in derived test will override the values of the fields of the cfg_num type object.
In reply to Alay Patel:
Hi Alay Patel,
Thanks for your response.
Can you please explain it little bit more or better u give some example so that I can understand it more clearly.
Manish
Hi Alay Patel,
I think I got it.
I took another handle of config class in derived class and updating required fields and then assigning handle of cfg_init (handle taken in derived class) to cfg_num (handle taken in base class).
Fatal Error is gone now.
config cfg_init[`num];
super.build(phase);
cfg_init[i].passive_cfg.intf_type=“CDE”;
cfg_init[i].t_m_init=100;
cfg_init[i].t_s_init=100;
cfg_num[i] = cfg_init[i];
endtask;
Manish
With this approach, you are losing out on any settings done in base_class.
