How to override uvm_config_db from extended class?
In reply to ms_1202:
You don’t need to set it again in derived class as while setting the cfg_num through uvm_config_db::set in base test passes the handle of the cfg_num type object.Thus assigning it in derived test will override the values of the fields of the cfg_num type object.
