I have a 10 bit DUT input wire ‘in’, that is being driven from the TB with value 0 by default, as shown below.
module my_tb;
mydut dut (
// other connections
.in(0));
In my test, I would like to override this value with a random value in the configure phase
class my_test extends base_test;
`uvm_component_utils(my_test)
bit [9:0] rand_val;
function new(string name = "my_test", uvm_component parent = null);
super.new(name,parent);
virtual task configure_phase(uvm_phase phase);
std::randomize(rand_val);
repeat(1) @(posedge clk);
my_tb.dut.in[9:0] = rand_val;
The line my_tb.dut.in[9:0] = rand_val; gives me the error: “Non reg type is not valid on the left hand side of this assignment”
If I do assign my_tb.dut.in[9:0] = rand_val;, I get the error: “Bit select or part select cannot be used on the left hand side of this assignment”
If I do force my_tb.dut.in[9:0] = rand_val;, I get the error: “Class data is not allowed in non-procedural context.”
How can I drive an input wire to the DUT from my test?
