How to manage different class in different file
I am working on example project (edaplayground)
It is divided into two different files (DUT & testbench)
testbench has several classes in one file
When I compile two files, no problem exist
However, when I divided testbench into several files (based on class name), then I compile with “filelist.f” such as
filelist.f
reg_ctrl.sv #<-- DUT
reg_item.sv
driver.sv
monitor.sv
scoreboard.sv
environment.sv
interface.sv
test.sv
tb_top.sv
However, I got compile error as below
QuestaSim-64 vlog 10.5b Compiler 2016.05 May 21 2016
Start time: 12:52:10 on Aug 18,2020
vlog -reportprogress 300 -incr “+cover=bcestf” -f filelist.f
– Skipping module reg_ctrl
– Compiling package reg_item_sv_unit
** Error: (vlog-13069) driver.h(6): near “driver”: syntax error, unexpected IDENTIFIER.
** Error: driver.h(6): (vlog-13205) Syntax error found in the scope following ‘class’. Is there a missing ‘::’?
** Error: (vlog-13069) monitor.h(6): near “monitor”: syntax error, unexpected IDENTIFIER.
** Error: monitor.h(6): (vlog-13205) Syntax error found in the scope following ‘class’. Is there a missing ‘::’?
** Error: (vlog-13069) scoreboard.h(6): near “scoreboard”: syntax error, unexpected IDENTIFIER.
** Error: scoreboard.h(6): (vlog-13205) Syntax error found in the scope following ‘class’. Is there a missing ‘::’?
** Error: (vlog-13069) environment.h(17): near “env”: syntax error, unexpected IDENTIFIER.
** Error: environment.h(17): (vlog-13205) Syntax error found in the scope following ‘class’. Is there a missing ‘::’?
** Warning: environment.h(17): (vlog-2283) Extra semicolon in $unit (global) scope.
** Warning: scoreboard.h(6): (vlog-2283) Extra semicolon in $unit (global) scope.
** Warning: monitor.h(6): (vlog-2283) Extra semicolon in $unit (global) scope.
** Warning: driver.h(6): (vlog-2283) Extra semicolon in $unit (global) scope.
** Error: (vlog-13069) test.h(3): near “test”: syntax error, unexpected IDENTIFIER.
** Error: test.h(3): (vlog-13205) Syntax error found in the scope following ‘class’. Is there a missing ‘::’?
** Error: (vlog-13069) tb_top.sv(21): near “;”: syntax error, unexpected ‘;’, expecting ‘(’.
** Error: tb_top.sv(28): (vlog-2730) Undefined variable: ‘t0’.
** Warning: test.h(3): (vlog-2283) Extra semicolon in $unit (global) scope.
End time: 12:52:10 on Aug 18,2020, Elapsed time: 0:00:00
Errors: 12, Warnings: 5
** Error: C:/questasim64_10.5b/win64/vlog failed.
Error in macro ./Compile.do line 1
while executing
“vlog -incr +cover=bcestf -f filelist.f”
Did I miss something?
Can you tell me how to divide classes into different files?
Thank you
In reply to tw011:
It’s best to put your classes in a package and `include them instead of putting them on the command line
my_pkg.sv
package my_pkg;
`include "reg_item.sv"
`include "driver.sv"
`include "monitor.sv"
`include "scoreboard.sv"
`include "environment.SystemVerilog"
endpackage
And then replace these files with my_pkg.sv in your filelist. Also see SystemVerilog Coding Guidelines: Package import versus `include - Verification Horizons
Dear Dave
I have added `include “xxxx.sv” into my_pkg.sv as you mentioned
First question is
Based on your information, Only Class definition should be in package. Am I on correct approach? (interface.sv should be in tb_top ?)
Second question is
I have modified my_pkg.sv as below
package my_pkg;
include "reg_item.sv" include “driver.sv”
include "monitor.sv" include “scoreboard.sv”
include "test.sv" include “environment.sv”
endpackage
However, I still got error as below
– Skipping package my_pkg
– Skipping interface reg_if
** Error: (vlog-13069) tb_top.sv(25): near “;”: syntax error, unexpected ‘;’, expecting ‘(’.
** Error: tb_top.sv(32): (vlog-2730) Undefined variable: ‘t0’.
– Compiling module reg_ctrl
End time: 13:08:17 on Aug 19,2020, Elapsed time: 0:00:00
Errors: 2, Warnings: 0
while executing
Did I miss something? or Do I have to include or import “test class” on tb_top separately?
I hope you can comment on my mistake.
Thank you
In reply to tw011:
while including the files in the package we have too follow the order
  1. transaction class
  2. all the transactors in any order(driver, monitor, generator , SB etc)
  3. environment
  4. test
And the package has to be imported in the top module.
Regards,
Shanthi V A
