HI,
I am trying out backdoor access to a HDL path in VHDL design and I get fatal error when I am checking correctness of HDL path. To me it seems like DPI function doesn’t support VHDL based paths. What would you suggest to handle such scenario? As I can’t find much in related article.
Best Regards,
Usman
In reply to muhammad_usman_tanveer:
I have a UVM Register testbench working with an example VHDL DUT.
The UVM Register block build method uses the add_hdl_path method to define the path as shown below
I had an instance ‘dut’ in my testbench and my registers resides in that level of the hierarchy.
add_hdl_path("top.dut");
RegA_h = RegA::type_id::create("RegA_h");
RegA_h.configure(this, null, "data_RegA_h_local");
RegA_h.build();
RegB_h = RegB::type_id::create("RegB_h");
RegB_h.configure(this, null, "data_RegB_h_local");
RegB_h.build();
Hope that helps
Graeme
In reply to graeme_jessiman:
Hi Graeme,
I had such method call in my uvm_reg_block class. And in my uvm_reg class each field has its own hdl path.
I got dpi call related fatal error message while trying out uvm built-in sequence for checking correctness of HDL paths. This leads me to the observation that dpi calls might not support VHDL related paths.
Best Regards,
Usman
