Hi.
As I understand about uvm_analysis_imp_decl, it used for multiple analysis_imp.
https://verificationacademy.com/forums/uvm/uvmanalysisimpdecl
Trying to understand uvm_analysis_imp_decl I made a simple example.
`uvm_analysis_imp_decl(_port_a)
`uvm_analysis_imp_decl(_port_b)
`uvm_analysis_imp_decl(_port_c)
class component_b extends uvm_component;
transaction trans;
uvm_analysis_imp_port_a #(transaction,component_b) analysis_imp_a;
uvm_analysis_imp_port_b #(transaction,component_b) analysis_imp_b;
uvm_analysis_imp_port_c #(transaction,component_b) analysis_imp_c;
`uvm_component_utils(component_b)
// Constructor
super.new(name, parent);
analysis_imp_a = new("analysis_imp_a", this);
analysis_imp_b = new("analysis_imp_b", this);
analysis_imp_c = new("analysis_imp_c", this);
endfunction : new
// Analysis port write method
virtual function void write_port_a(transaction trans);
`uvm_info(get_type_name(),$sformatf(" Inside write_port_a method. Recived trans On Analysis Imp Port"),UVM_LOW)
`uvm_info(get_type_name(),$sformatf(" Printing trans, \n %s",trans.sprint()),UVM_LOW)
virtual function void write_port_b(transaction trans);
`uvm_info(get_type_name(),$sformatf(" Inside write_port_b method. Recived trans On Analysis Imp Port"),UVM_LOW)
virtual function void write_port_c(transaction_c trans_c);
`uvm_info(get_type_name(),$sformatf(" Inside write_port_c method. Recived trans On Analysis Imp Port"),UVM_LOW)
`uvm_info(get_type_name(),$sformatf(" Printing trans_c, \n %s",trans_c.sprint()),UVM_LOW)
endclass : component_b
`include "transaction.sv"
`include "transaction_c.sv"
`include "component_a.sv"
`include "component_b.sv"
`include "component_c.sv"
class environment extends uvm_env;
// Components Instantiation
component_a comp_a;
component_b comp_b;
component_c comp_c;
`uvm_component_utils(environment)
// Constructor
endfunction : new
// build_phase - Create the components
super.build_phase(phase);
comp_a = component_a::type_id::create("comp_a", this);
comp_b = component_b::type_id::create("comp_b", this);
comp_c = component_c::type_id::create("comp_c", this);
endfunction : build_phase
// Connect_phase
comp_a.analysis_port.connect(comp_b.analysis_imp_a);
comp_a.analysis_port.connect(comp_b.analysis_imp_b);
comp_c.analysis_port.connect(comp_b.analysis_imp_c);
endfunction : connect_phase
endclass : environment
But I got the error.
# ** Error: (vsim-7065) Illegal assignment to class /usr/share/questa/questasim//uvm-1.2.uvm_pkg::uvm_port_base #(class /usr/share/questa/questasim//uvm-1.2.uvm_pkg::uvm_tlm_if_base #(class work.testbench_sv_unit::transaction_c, class work.testbench_sv_unit::transaction_c)) from class work.testbench_sv_unit::uvm_analysis_imp_port_c #(class work.testbench_sv_unit::transaction, class work.testbench_sv_unit::component_b)
# Time: 0 ns Iteration: 0 Region: /testbench_sv_unit File: environment.sv Line: 44
# ** Error: (vsim-8754) Actual input arg. of type 'class work.testbench_sv_unit::uvm_analysis_imp_port_c #(class work.testbench_sv_unit::transaction, class work.testbench_sv_unit::component_b)' for formal 'provider' of 'connect' is not compatible with the formal's type 'class /usr/share/questa/questasim//uvm-1.2.uvm_pkg::uvm_port_base #(class /usr/share/questa/questasim//uvm-1.2.uvm_pkg::uvm_tlm_if_base #(class work.testbench_sv_unit::transaction_c, class work.testbench_sv_unit::transaction_c))'.
# Error loading design
I can’t understand “comp_c.analysis_port.connect(comp_b.analysis_imp_c);” why does it make error?
