I read that Multiple Transaction Streams With Synchronization
https://verificationacademy.com/cookbook/analysisconnections
task run_phase( uvm_phase phase );
alu_txn before_txn, after_txn;
forever begin
before_fifo.get(before_txn);
after_fifo.get(after_txn);
if (!before_txn.compare(after_txn)) begin
`uvm_error("Comparator Mismatch",
$sformatf("%s does not match %s", before_txn.convert2string(), after_txn.convert2string()))
m_mismatches++;
end else begin
m_matches++;
and I made one simple example as reference code.
class component_a extends uvm_component;
transaction trans;
uvm_analysis_port#(transaction) analysis_port;
`uvm_component_utils(component_a)
super.new(name, parent);
analysis_port = new("analysis_port",this);
phase.raise_objection(this);
for(int a=0; a<10; a++) begin
trans = transaction::type_id::create("trans");
if (!trans.randomize())
`uvm_fatal("RNDERR", "Randomization of trans failed");
analysis_port.write(trans);
`uvm_info(get_type_name(), "Trans Sending....",UVM_LOW)
phase.drop_objection(this);
class component_b extends uvm_component;
`uvm_component_utils(component_b)
transaction trans;
uvm_tlm_analysis_fifo#(transaction) analy_fifo;
analy_fifo = new("analy_fifo", this);
forever begin
`uvm_info(get_type_name(), $sformatf(" FIFO used: %0d", analy_fifo.used()), UVM_LOW)
if(analy_fifo.is_empty()) begin
`uvm_info(get_type_name(), "FIFO is Empty!!!!!",UVM_LOW)
else begin
analy_fifo.get(trans);
`uvm_info(get_type_name(),$sformatf(" Printing receive trans, \n ",trans.sprint()),UVM_LOW)
This test never finished when I ran the test.
UVM_INFO component_b.sv(49) @ 0: uvm_test_top.env.comp_b [component_b] FIFO is Empty!!!!!
UVM_INFO component_b.sv(46) @ 0: uvm_test_top.env.comp_b [component_b] FIFO used: 0
How do I finish the forever loop until component_a done?
