class register1 extends uvm_reg;
`uvm_object_utils(register1 )
rand uvm_reg_field field1;
rand uvm_reg_field field2;
rand uvm_reg_field field3;
covergroup cg_field_values ();
option.per_instance = 1;
cg_field1 : coverpoint field1.value ;
cg_field2 : coverpoint field2.value ;
cg_field3 : coverpoint field3.value ;
endgroup
// Constructor
function new(string name = "eth_f_all_reg_config_urm");
super.new(name,32,build_coverage(UVM_CVR_FIELD_VALS));
if (has_coverage(UVM_CVR_FIELD_VALS)) begin
cg_field_values = new();
cg_field_values.set_inst_name({get_full_name(), ".cg_field_values"});
endfunction : new
// Build
virtual function void build();
// creating and configuring reg fields
function void sample_values();
super.sample_values();
if (get_coverage(UVM_CVR_FIELD_VALS)) begin
if(cg_field_values!=null) cg_field_values.sample();
class register2 extends uvm_reg;
`uvm_object_utils(register2 )
endgroup
// Constructor
endfunction : new
// Build
class my_reg_block extends uvm_reg_block;
`uvm_object_utils(my_reg_block )
rand register1 reg1;
rand register2 reg2;
//Constructor
function new(string name = "my_reg_block");
super.new(name,build_coverage(UVM_CVR_ALL));
endfunction : new
//Build
// Creating and configuring registers
class my_env extends uvm_env;
my_reg_block reg_b;
/// inside build_phase ()
reg_b = my_reg_block::type_id::create("my_reg_block");
reg_b.build();
I have shown the 2 template registers in my register blocks .I have many registers in my reg_block similar to them.
All those register files are getting generated using code generator.
They are passing UVM_CVR_FIELD_VALS when creating parent from new function of register1 and register2 …
They are getting created in my env.
I don’t want to create those registers. If i change UVM_CVR_FIELD_VALS to UVM_NO_COVERAGE , they are not getting created.
As i mentioned , they are getting generated from code generator. If i change register files, they will get overriden by the registers that are generated in next release .
I need to change them manually again.
I want to control register creation from my env. Is there any way to do that?
I tried adding below in my env build_phase after creating reg_block, but it did not work
reg_b.set_coverage(UVM_NO_COVERAGE);
Please suggest me a better way!
Thanks in advance.
