How to deep copy UVM transaction containing queue of objects?
I have a UVM transaction extended from uvm_sequence_item (call it ‘txn’). It contains a queue of object defined as “base_obj obj_queue[$]”. The base_obj is a virtual class with pure virtual do_copy function. Concrete classes extended from base_obj are stored in obj_queue. When I implement ‘do_copy’ function in the ‘txn’ transaction, how do I deep copy obj_queue containing different types derived from base_obj?
class txn extends uvm_sequence_item
  base_obj obj_queue[$];
  // do_copy implementation  - how do I deep copy 'obj_queue'?
// abstract 'base_obj' class
virtual class base_obj extends uvm_object;
// concrete classes derived from base_obj
class obj_a extends base_obj
  //(do_copy implementation)
class obj_b extends base_obj
In the do_copy function of txn class, you can simply do:
obj_queue = rhs_.obj_queue;
Make sure in your extended classes that you call super.do_copy().
This would only copy handles of each object in the queue though. I want to clone (deep copy) each object in the queue.
I tried doing following in do_copy() method of “txn” class:
function void txn::do_copy(uvm_object rhs);
   if (!$cast(rhs_, rhs)) `uvm_fatal("rhs_ Cast Failed!")
   this.obj_queue.delete();
   foreach(rhs_.obj_queue[i])
       base_obj obj;
       if (!$cast(obj, rhs_.obj_queue[i].clone())) `uvm_fatal("obj Cast Failed!")
       this.obj_queue.push_back(obj);
…but I was getting following error:
base_obj.sv(82): Illegal call to pure virtual method 'do_copy’ in ‘txn’ .
I had ‘do_copy’ defined as a “pure virtual function” in the base_obj.sv because I wanted to enforce each derived object implement this function. Removing “pure virtual function” definition from the base_obj fixed the issue. However, I wonder if there are other ways to clone concrete objects stored in the rhs_.obj_queue and then copy the cloned objects in this.obj_queue without removing “pure virtual function” definition from the base_obj.sv.
It’s easier to implement the do_copy in your base txn class.
Using clone to duplicate the objects will work fine, but remember that the class using the objects in the base_obj queue will need to cast them to the correct type.
