for eg: we have first dynamic array of 8 elements say:
dyn1=new[8];
dyn[0]=2;dyn[1]=1;dyn[2]=4;dyn[3]=6;dyn[4]=9;dyn[5]=7;dyn[6]=14;dyn[7]=65;
dyn2=new10;
dyn2[0]=4;dyn2[1]=0;
then the result i am getting is 2,1,4,6,9,7,14,65,0,0;
and if i am making it as dyn2[8]=4,dyn2[9]=0;
its displaying as 2,1,4,6,9,7,14,65,4,0;
but what if i want to get the print as 4,0,2,1,4,6,9,7,14,65? means first to display the newly written value on dyn2 and then the copied values of dyn1??
Given that there are typos in your example here, I am assuming there may be other typos in your code. It always helps if you can cut and paste a complete example. The result I get after changing dyn to dyn1, and completing the rest of your code is
# '{4, 0, 4, 6, 9, 7, 14, 65, 0, 0}
If you will be frequently adding array elements, it is better to use a queue or an associative array than an dynamic array. As a Queue, your code can be written as
int dyn1[$],dyn2[$];
dyn1={2, 1, 4, 6, 9, 7, 14, 65};
dyn2= {4,1,dyn1};
// the most efficent way to add items to a queue is to push() or insert().
// dyn2 = dyn1;
// dyn2.push_front(0);
// dyn2.push_front(4);
$display("%p",dyn2);
