I’m trying to implement multiple interface into DUT.
`include "interface.sv"
`include "test.sv"
module tbench_top;
//creatinng instance of interface
intf i_intf();
i2c_intf i_i2c_intf();
//Testcase instance
test t1(i_intf);
//DUT instance, interface signals are connected to the DUT ports
adder DUT (
.a(i_intf.a),
.b(i_intf.b),
.c(i_intf.c),
.i_scl_in(i_i2c_intf.i_scl_in),
.o_sda_out(i_i2c_intf.o_sda_out)
But I have some problem what I try to instance interface as below I got the error message.
** at environment.sv(18): Multiple constructors declared for class environment - only one allowed.
`include "environment.sv"
module test(intf i_intf);
//declaring environment instance
environment env;
//creating environment
env = new(i_intf);
//calling run of env
env.run();
class environment;
//virtual interface
virtual intf vif;
virtual i2c_intf i2c_vif;
//constructor
function new(virtual intf vif);
//get the interface from test
this.vif = vif;
//constructor
function new(virtual i2c_intf i2c_vif);
this.i2c_intf = i2c_vif;
//run task
task run;
vif.a = 6;
vif.b = 4;
$display("Value of a = %0d, b = %0d",vif.a,vif.b);
#5;
$display("Sum of a and b, c = %0d",vif.c);
$finish;
[2022-02-16 08:22:55 EST] vlib work && vlog -writetoplevels questa.tops ‘-timescale’ ‘1ns/1ns’ design.sv testbench.sv && vsim -f questa.tops -batch -do “vsim -voptargs=+acc=npr; run -all; exit” -voptargs=+acc=npr
QuestaSim-64 vlog 2021.3_1 Compiler 2021.08 Aug 15 2021
Start time: 08:22:55 on Feb 16,2022
vlog -writetoplevels questa.tops -timescale 1ns/1ns design.sv testbench.sv
– Compiling module adder
– Compiling interface intf
– Compiling interface i2c_intf
** Error: ** while parsing file included at testbench.sv(6)
** while parsing file included at test.sv(1)
End time: 08:22:55 on Feb 16,2022, Elapsed time: 0:00:00
Errors: 1, Warnings: 0
Exit code expected: 0, received: 1
You have two new() functions (constructors) in your environment class. This is why you have an error. You should have only one new() function and pass both interface handles as arguments.
BTW, we strongly recommend using the uvm_config_db to pass information to a class instance instead of adding extra arguments to the constructor. Adding constructor arguments prevents using the UVM factory, and also leads to “argument creep” when adding inheritance or hierarchical class structures.
It means the number of places that have to deal with the argument creeps up in number. This example only has one layer of class construction, but let’s add another layer.
class test;
env e;
e = new(i2c_vif);
If you need to change the interface type, you have to change it in two places. Now lets and another env with a different virtual interface; you have to and another argument to the test class. In a typical UVM testbench, there are several layers of components (test->env->agent->driver). You don’t want to have to change all the intermediate level classes just because you made a change at the lowest level.
Oh I see what you mean. Passing variable by constructor requires that each level has the same constructor signature, while passing variable by config_db is a nice way of using global variable/hashmap.
In reply to cgales:
Dear Dave_59,
Could you give some guide example code for “using the uvm_config_db to pass information” into my situation to avoid “argument creeps” for understading?
You posted this question in the UVM forum, so we assume you’re already using the UVM.
But even if you’re not, you could still
import this one class from the UVM library into your testbench. Or worst case, reinvent similar functionality in your testbench.
In reply to UVM_LOVE: You posted this question in the UVM forum, so we assume you’re already using the UVM.
