How to check clock frequency through asserions
I have a clk frequency randomized between 10Mhz -100Mhz and want to check the frequency through assertions … whether frequency is correct or not ,Can any one help me , how to resolve below error…and I am using cadence ncsim…
//Checking clock period range
assert property (period_chk)
$error(0,“Wrong clock frequency”,$time);
property period_chk;
time current_time;
$rose(smb_clk) ('1,current_time = $time/1000000) |-> $rose(smb_clk) (($time/1000000)-current_time <= 100) && ($time/1000000)-current_time >= 10));
Error :
ncvlog: *E,ALXSCN (/iel-storage1/home/sdasari/SMBUS_VIP/verif/tb/smbus_assertions.sv,48|19): Expected specification terminator “;”.
I understand that you want to trigger the time sampling at one posedge of smb_clk and check if the time difference is within the desired range at the following posedge.
For this, you should change $rose with @(posedge smb_clk) (to trigger the sampling), and use the non-overlapping implication operator |=> instead of |-> so that the next posedge does not overlap with the current one, like this :
    time current_time;
    @(posedge smb_clk) (1, current_time = $time/1000000) |=> @(posedge smb_clk)      (($time/1000000-current_time <= 100) && ($time/1000000-current_time >= 10));
The following would be easier. Add the timeunit, timeprecision.
module timem;
   timeunit 1ns; timeprecision 100ps;
   bit clk, a, b;
   initial forever #5 clk=!clk;
      time current_time;
       ('1,current_time = $time ) ##1
       	  ($time -current_time == 10ns);
   ap_time: assert property(@(posedge clk) period_chk);
  • SystemVerilog Assertions Handbook 3rd Edition, 2013 ISBN 878-0-9705394-3-6
