I know that in VERA simulation, we can use +vera_random_seed=$(SEED) to change random seed without to re-compile. In fact i use shell script to get current time and pass it to vera seed. Every time I run simulaiton, the random data is not the same, it is very convenient.
I was wondering whether systemverilog has the same mechanics to change rand seed at command line.
In Questa, you can use the vsim switch -sv_seed [value]. You can also use random as value to generate unique seeds. It will print out the seed so you can replay it.
This is going to be tool specific, so you should contact your tool vendor directly. In general, the simulator must seed all the original starting processes (initial/always/static initialization processes) before even getting to the run command.
Thanks Dave. I have a related question :). Is it possible to change the seed from the GUI of QuestaSim 10.3e?. Sometimes you don’t want to close the GUI to simulate a new seed. How do you do that? I haven’t found any command to do this from command line. The “run” options doesn’t allow you to change the seed. Isn’t it?
Thanks in advance
Thanks for your answer.
I would like to know about QuestaSIM 10.3e. I use Questa with UVM. Is it possible with the Mentor simulator?
Bye the way thanks a lot for all the contributions in Verification Academy. The forum is very useful
I have another question.
If you want to reseed your simulation using “-sv_seed random” and then you want to see the value (without using logs/transcript) of the used seed, is there any variable in Questa to display the current seed?
We currently have some buttons in the modelsim GUI one to generate a random seed just for fun :) and other to rerun simulation cleaning the transcript. After cleaning the transcript the printed value from the original vsim seed get lost, however we would like to request always that value.
Is it possible?
Thanks in advance
I have used a workaround to solve my problem
See my button code in tcl below
#we need to wait some time (for the GUI) to load the buttons
after 5000 init_gui
# add the buttons
proc init_gui {} {
global buttons_added
if { ![info exists buttons_added] } {
add_button
set buttons_added 1
proc add_button {} {
apply_button_adder main controls right green black reseed {reseedbutton}
proc reseedbutton {} {
#vsim $argv -sv_seed random
set tmpwave "/tmp/$::tcl_platform(user)_[clock microseconds]_wave.do"
# avoid error message if wave window does not exist
if { [catch { write format wave -window .main_pane.wave.interior.cs.body.pw.wf $tmpwave }] == 0 } {
delete wave *
transcript file tmp
transcript file transcript
set random [expr {int(rand()*1000000)}]
regsub -all {\-sv_seed +[0-9]+} $::argv {} ::argv
set ::argv "$::argv -sv_seed $random"
echo "vsim $::argv"
if { $::argv != {}} { eval vsim $::argv}
run 0 # we run 0 to make the transactions visible in questa
do $tmpwave
file delete $tmpwave
# BONUS button do rerunbutton
proc do_rerunbutton_cmd {{cmd {}}} {
delete wave *
restart -f
transcript file tmp
run 0
do $tmpwave
if { $cmd != {}} { eval $cmd}
Then each time we push reseed button the seed variable will be in the “echo $argv” variable
