90% verification done, after in RTL some changes went and without effect the previous results, how I can conclude now it’s working fine or not within one hour(Time limit)??
In reply to Subbi Reddy:
You have been to a lot of interviews. ![]()
There are two technologies you could employ here.
- Sequential Logic Equivalence Checking. If the changes are in a small enough area, formal equivalence checking gives you a quick exhaustive answer to whether thee functionality remains the same.
- Test Plan Tracking (or Test Ranking). If you built up a suite of regression tests, testplan track can help you select the shortest tests to run to cover the functionality in the blocks that have been modified
In three interviews only asked lot of Questions :)
Test plan cracking was helpful for variables changes( two or more variables values changes)??
