Error-[PIWDOAACS] Incorrectly used ‘disable iff’
Property instances with ‘disable iff’ are only allowed in “assert” “assume” and “cover” statements. Property p_RiseIntDischeck may not be instantiated in this context.
seq_a and seq_b is already declared and being used for some other assertion. What is the best/recommended way to reuse these sequences/properties and create a negative scenario checker for the above case?
In reply to vvs3693:
In general, assertions should be expressed in a ‘positive’ direction,
meaning “if trigger_conditions then expected_resuls”. Thus, for
// the status should never go high @ next cycle when either req or enable is low
ap_reqenb: assert property(
!req || !enb |=> status==0);
You should also use Binary logical operators (e.g., && ||) instead of Binary bitwise operators (e.g., & | ), as they have different meanings.
Below is updated code that compiles and elaborates OK. Your code has lots of errors; I am surprised that it compiled.
bit clk, a;
initial forever #10 clk=!clk;
int idx;
logic[0:7] req, enable, status, f_enable, f_req;
/* Is there a way to assert whether a already declared property is false at every clock cycle?
For example,
status[idx] should be high only if both req[idx] and enable[idx] is high.
What I would like to have is a negative scenario checker for the above.
i.e. the status should never go high when either req or enable is low
I tried below but vcs gives me below compilation error*/
sequence seq_a (int idx);
!(req[idx] & enable[idx]); // !(a&&b) !a || !b
endsequence
sequence seq_b (int idx);
status[idx] == 0; // the status should never go high when either req or enable is low
endsequence
property ppty_ab (int idx);
disable iff (f_req[idx] & f_enable[idx])
seq_a(idx) |=> seq_b(idx);
generate
for (genvar idx=0; idx<5; idx++) begin
a_ab : assert property (@(posedge clk) ( ppty_ab(idx)))
else $display("ppty_ab [%0d] failed at %t",idx,$time);
endgenerate
