How to achieve fork-join_none and fork join_any functionality using fork-join
//fork join_none functionality using fork join
initial
          begin : b1
            #5 $display($time, " from block b1");
          end : b1
          begin : b2
            #10 $display($time, " from block b2");
          end : b2
      join
    $display($time, " from outside fork-join block");
how to make it work like fork join_none and fork join_any
In reply to MadhavSrikantam:
Although it’s possible to make this contrived example work like join_none or join_any
event ev_any, ev_none;
initial
          begin : b1
            -> ev_none;
            -> ev_any;
          end : b1
          begin : b2
            -> ev_none;
            -> ev_any;
          end : b2
          @(ev_none) // replace with @(ev_any) to get join_any functionality
      join
It would be very difficult to get this functionality was embedded inside a task or loop.
initial
          begin : b1
          end : b1
          begin : b2
          end : b2
      join
#                    5 from block b1
#                   10 from block b2
#                   10 from outside fork-join block
this is the output which i get for the above code using fork-join_none
initial
          begin : b1
          end : b1
          begin : b2
          end : b2
      join_none
#                    0 from outside fork-join block
#                    5 from block b1
#                   10 from block b2
this is the output for the code with fork-join_none
my doubt is what should be done to the first code so that i get the output as the second one
Your question is lacking a purpose. The code I showed you above produce the same results as the fork/join_none. Here is another example
  initial
          begin : b1
          end : b1
 initial
          begin : b2
          end : b2
 initial
There are many ways to get the same output results. but there is no way to spawn a process in the background without join_none or join_any.
Understood,
Thank you for your reply
This does not seem to work. Looks like the event is not shared between threads. I do not understand why.
Output:
run -all
5 from block b1
10 from block b2
The reason this is not working for join_none implementation is, for ev_none event the wait statement and triggering is being executed at the same time. We should replace the blocking trigger(->) with non-blocking trigger(->>) or change the @(ev_none); to wait(ev_none.triggered);
Here’s the updated code for fork/join_none using fork/join:
event  ev_none;
initial
          begin : b1
            ->> ev_none;
          end : b1
          begin : b2
            ->> ev_none;
          end : b2
      join
