Thanks !
After changing the verbosity it got printed.
UVM_INFO /data/i2c_to_reg_adapter.sv(144) @ 1464320000000: reporter [i2c_adapter] REG2BUS called for I2C
But my .write method is calling I2C REG2BUS , but i want that it should call Soundwire protocol REG2BUS .
how to make sure that this happens.
I am getting below prints from I2C adapter
UVM_INFO /i2c_to_reg_adapter.sv(144) @ 1464320000000: reporter [i2c_adapter] REG2BUS called for I2C
UVM_INFO /i2c_to_reg_adapter.sv(170) @ 1467805000000: reporter [i2c_adapter] BUS2REG called for I2C
UVM_INFO /i2c_to_reg_adapter.sv(205) @ 1467805000000: reporter [i2c_adapter] Page switched to 0
UVM_INFO /i2c_to_reg_adapter.sv(211) @ 1467805000000: reporter [i2c_adapter] ADAPTER: WRITE, current_page=0, 2c_trans.reg_addr=0,address=0
UVM_INFO /i2c_to_reg_adapter.sv(170) @ 1471290000000: reporter [i2c_adapter] BUS2REG called for I2C
UVM_INFO /i2c_to_reg_adapter.sv(211) @ 1471290000000: reporter [i2c_adapter] ADAPTER: WRITE, current_page=0, 2c_trans.reg_addr=10,address=10
UVM_INFO /i2c_to_reg_adapter.sv(144) @ 1471290000000: reporter [i2c_adapter] REG2BUS called for I2C
UVM_INFO /i2c_to_reg_adapter.sv(170) @ 1474775000000: reporter [i2c_adapter] BUS2REG called for I2C
UVM_INFO /i2c_to_reg_adapter.sv(205) @ 1474775000000: reporter [i2c_adapter] Page switched to 0
UVM_INFO /i2c_to_reg_adapter.sv(211) @ 1474775000000: reporter [i2c_adapter] ADAPTER: WRITE, current_page=0, 2c_trans.reg_addr=0,address=0
UVM_INFO /i2c_to_reg_adapter.sv(170) @ 1478260000000: reporter [i2c_adapter] BUS2REG called for I2C
UVM_INFO /i2c_to_reg_adapter.sv(211) @ 1478260000000: reporter [i2c_adapter] ADAPTER: WRITE, current_page=0, 2c_trans.reg_addr=11,address=11
UVM_INFO /i2c_to_reg_adapter.sv(144) @ 1478260000000: reporter [i2c_adapter] REG2BUS called for I2C
UVM_INFO /i2c_to_reg_adapter.sv(170) @ 1481745000000: reporter [i2c_adapter] BUS2REG called for I2C
UVM_INFO /i2c_to_reg_adapter.sv(205) @ 1481745000000: reporter [i2c_adapter] Page switched to 0
UVM_INFO /i2c_to_reg_adapter.sv(211) @ 1481745000000: reporter [i2c_adapter] ADAPTER: WRITE, current_page=0, 2c_trans.reg_addr=0,address=0
UVM_INFO /i2c_to_reg_adapter.sv(170) @ 1485230000000: reporter [i2c_adapter] BUS2REG called for I2C
UVM_INFO /i2c_to_reg_adapter.sv(211) @ 1485230000000: reporter [i2c_adapter] ADAPTER: WRITE, current_page=0, 2c_trans.reg_addr=12,address=12
UVM_INFO /i2c_to_reg_adapter.sv(144) @ 1485230000000: reporter [i2c_adapter] REG2BUS called for I2C
UVM_INFO /i2c_to_reg_adapter.sv(170) @ 1488715000000: reporter [i2c_adapter] BUS2REG called for I2C
UVM_INFO /i2c_to_reg_adapter.sv(205) @ 1488715000000: reporter [i2c_adapter] Page switched to 0
UVM_INFO /i2c_to_reg_adapter.sv(211) @ 1488715000000: reporter [i2c_adapter] ADAPTER: WRITE, current_page=0, 2c_trans.reg_addr=0,address=0
UVM_INFO /i2c_to_reg_adapter.sv(170) @ 1492200000000: reporter [i2c_adapter] BUS2REG called for I2C
UVM_INFO /i2c_to_reg_adapter.sv(211) @ 1492200000000: reporter [i2c_adapter] ADAPTER: WRITE, current_page=0, 2c_trans.reg_addr=13,address=13
