Hello,
I am trying to write an assertion for the following specification.
ack must arrive within 8 clocks.
$rose(req) must not arrive more than 3 times before ack arrives.
Not able to write a correct assertion.
Thanks much.
Hello,
Thanks much.
In reply to ashokmehta72:
ack must arrive within 8 clocks from 1sr rose(req).
You need support logic to exclude new $roses from the 1st one. Below is pseudo-code.
bit lock;
function void setlock(bit v);
lock=v;
assert property(($rose(req) && lock==0, setlock=1) |->
##[1:8] ack) setlock=0; else setlock=0; // reset the lock
//pass or fail
// $rose(req) must not arrive more than 3 times before ack arrives
assert property($rose(req) && lock==0 ¦=> ($rose(req)[=1]) [*0:2] ##1 ack);
Ben systemverilog.us
In reply to ash72:
You may want to consider
I updated the previous reply
// I had the right concept, but the wrong variable
// b[=m] is equivalent to ( b [->m] ##1 !b [*0:$] )
// b[->m] is equivalent to ( !b [*0:$] ##1 b)[*m]
