I generated and send 10 randomized transaction by “uvm_tlm_analysis_fifo” in uvm_component_a, I expected that I can get 10 transferred randomized transaction from component_b.
But I can’t get 10 transferred randomized transactions from component_b.
case 1.
class component_a extends uvm_component;
transaction trans;
uvm_analysis_port#(transaction) analysis_port;
`uvm_component_utils(component_a)
super.new(name, parent);
analysis_port = new("analysis_port",this);
phase.raise_objection(this);
trans = transaction::type_id::create("trans", this);
for(int a=0; a<10; a++) begin
void'(trans.randomize());
analysis_port.write(trans);
phase.drop_objection(this);
class component_b extends uvm_component;
`uvm_component_utils(component_b)
transaction trans;
uvm_tlm_analysis_fifo#(transaction) analy_fifo;
analy_fifo = new("analy_fifo", this);
for(int i=0; i< 10; i++) begin
#100;
analy_fifo.get(trans);
`uvm_info(get_type_name(),$sformatf(" Printing trans, \n %s",trans.sprint()),UVM_LOW)
I got the result as the below,
UVM_INFO component_b.sv(20) @ 100: uvm_test_top.env.comp_b [component_b] Printing trans,
Name Type Size Value
trans transaction - @3131
addr integral 4 'h9
wr_rd integral 1 'h1
wdata integral 8 'he7
UVM_INFO component_b.sv(20) @ 200: uvm_test_top.env.comp_b [component_b] Printing trans,
addr integral 4 'h9
UVM_INFO component_b.sv(20) @ 300: uvm_test_top.env.comp_b [component_b] Printing trans,
addr integral 4 'h9
UVM_INFO component_b.sv(20) @ 400: uvm_test_top.env.comp_b [component_b] Printing trans,
addr integral 4 'h9
UVM_INFO component_b.sv(20) @ 500: uvm_test_top.env.comp_b [component_b] Printing trans,
addr integral 4 'h9
UVM_INFO component_b.sv(20) @ 600: uvm_test_top.env.comp_b [component_b] Printing trans,
addr integral 4 'h9
UVM_INFO component_b.sv(20) @ 700: uvm_test_top.env.comp_b [component_b] Printing trans,
addr integral 4 'h9
UVM_INFO component_b.sv(20) @ 800: uvm_test_top.env.comp_b [component_b] Printing trans,
addr integral 4 'h9
UVM_INFO component_b.sv(20) @ 900: uvm_test_top.env.comp_b [component_b] Printing trans,
addr integral 4 'h9
UVM_INFO component_b.sv(20) @ 1000: uvm_test_top.env.comp_b [component_b] Printing trans,
addr integral 4 'h9
So If I change with write() method instead of run_phase(),
Case2
transaction trans;
#100;
virtual function write(transaction trans);
There is no print out from write() method.
How do I get all transferred data by uvm_analysis_port in case1 and case2?
