How do I get all transferred data by uvm_analysis_port?
In reply to cgales:
In reply to UVM_LOVE:
I don’t understand your question.
The uvm_tlm_analysis_fifo is a class with a fifo and an internal write() method. When the connected analysis_port calls write(), the analysis_fifo will take the written item and push it to the fifo. You can then get() the transactions from the fifo as required.
Since the write() method is internal to the analysis_fifo, there is no requirement for you to implement a write() function.
What is not working in your first implementation?
My first implementation is
class component_a extends uvm_component;
  transaction trans;
  uvm_analysis_port#(transaction) analysis_port;
  `uvm_component_utils(component_a)
    super.new(name, parent);
    analysis_port = new("analysis_port",this);
    phase.raise_objection(this);
    trans = transaction::type_id::create("trans", this);
    for(int a=0; a<10; a++) begin
      void'(trans.randomize());
      analysis_port.write(trans);
    phase.drop_objection(this);
class component_b extends uvm_component;
  `uvm_component_utils(component_b)
  transaction trans;
  uvm_tlm_analysis_fifo#(transaction) analy_fifo;
    analy_fifo = new("analy_fifo", this);
    for(int i=0; i< 10; i++) begin
    #100;
      analy_fifo.get(trans);
      `uvm_info(get_type_name(),$sformatf(" Printing trans, \n %s",trans.sprint()),UVM_LOW)
As you can see, I send 10 transactions in component_a then I get the transactions from component_b.
Yes I understood like your comment, I thought that If I send 10 transactions then I can get 10 transactions.
But I get the same date.
This is the uvm_tlm_analysis_fifo even this is unbounded then all transactions supposed to be stored in the FIFO.
UVM_INFO component_b.sv(20) @ 800: uvm_test_top.env.comp_b [component_b]  Printing trans,
Name     Type         Size  Value
trans    transaction  -     @3131
  addr   integral     4     'h9
  wr_rd  integral     1     'h1
  wdata  integral     8     'he7
So this is not working first implemenation of my problem
