Good day,
I am working on a testbench for a design which has a large amount of individually instantiated interfaces. These interfaces should be connected to several modules each, and all-in-all the code for handling one of these interfaces is substantial. Therefore, I wish to find a way to loop through the individual interfaces and apply the same code to each of them. I first tried to make an array of the interfaces, but after some searching I found that this is not allowed in SystemVerilog.
So I thought: the generate construct’s for loops create indexable blocks which can contain modules. So if I create a module which does nothing but take in an interface, I can effectively create an array of these modules and plug each interface into one of them. Then I can use hierarchical access to get the interface by index. This is what the code below is attempting to do.
However, the if-statements in the ‘containers’ block are creating their own blocks, and I am only allowed to name them differently from each other. This means I am back to square one.
Is there any way in which I can get the below code to work, OR I can in some other way make the interfaces indexable without changing the ports of the TB? I cannot change the way in which the interfaces are instantiated.
interface in;
// contains interface signals
endinterface
module top (
in uin_0,
in uin_1,
in uin_2,
in uin_3
// design code
module driver (in uin);
// drives interface
module container (in uin);
// does nothing
module tb (
in uin_0,
in uin_1,
in uin_2,
in uin_3
generate
// This part has some duplicate code, but is perhaps a necessary evil
for (genvar i=0; i<4; i++) begin : containers
if (i==0) begin container inst ( .uin(uin_0) ); end
if (i==1) begin container inst ( .uin(uin_1) ); end
if (i==2) begin container inst ( .uin(uin_2) ); end
if (i==3) begin container inst ( .uin(uin_3) ); end
endgenerate
generate
for (genvar i=0; i<4; i++) begin : drivers
// This loop contains a lot more code which I do not wish to duplicate for each uin
driver u_driver (containers[i].inst.uin);
endgenerate
module harness ();
// Declare interfaces
in uin_0 ();
in uin_1 ();
in uin_2 ();
in uin_3 ();
top u_dut ( .uin_0(uin_0), .uin_1(uin_1), .uin_2(uin_2), .uin_3(uin_3) );
tb u_tb ( .uin_0(uin_0), .uin_1(uin_1), .uin_2(uin_2), .uin_3(uin_3) );
