I want to know more about how assumptions work in Formal tool
Is it advisable to use same signal in antecedent and consequent .
eg -
assume property(@(posedge clk) (a==0)|-> ##1 (a==1)[=1] );
Here my intention was to get signal a asserted for 1 cycle only in whole simulation.
But I am seeing it asserted for 2 back to back cycles .
Kindly help me in what I am doing wrong here.
In reply to ashish_banga:
if signal is one clock cycle wide . it should toggle only once.
it requires some support logic.
bit set_a_flag ;
function void set_flag(bit a_flag);
set_a_flag = a_flag ;
property a_toggle_once ;
@(posedge clk)
(a==0 ,set_a_flag==0,set_flag(1))|-> ##1 (a==1)[->1] #1 a ==0 ;
In reply to kddholak:
bit set_a_flag ;
@(posedge clk)
Your above code won’t compile.It’s illegal to have multiple sequence_expr for a sequence_match_item
I am not asking for alternate solutions. I have figured it out how to do in other ways.
I am asking what my mentioned assume is not working
In reply to MICRO_91:
Your code won’t compile.It’s illegal to have multiple sequence_expr for a sequence_match_item
Is it illegal to have multiple sequence_expr for a sequence_match_item ? What does it mean ?I don’t see any illegal in construct or usage in property.
I assume you haven’t tried your code . Try it out once
Refer Section 16.10 Local variables , Syntax16-14 of the LRM
