Hi …!
any one can you tell me that in copy method they are using uvm_object instead of uvm_sequence_item.
Thanks in advance
Hi …!
Thanks in advance
In reply to Bhimappa A Mali:
Hello,
Please get below mentioned details of copy method from “uvm_object.svh” file.
// The copy makes this object a copy of the specified object.
// The ~copy~ method is not virtual and should not be overloaded in derived
// classes. To copy the fields of a derived class, that class should override
// the <do_copy> method.
extern function void copy (uvm_object rhs);
Hope this has answered your question !
