Hi , i developed uvm tb for spi master core, when i am running tb with single test case , it was went up to master monitor and it is looping there it self due to forever in monitor run task,how to overcome this?
class wb_monitor extends uvm_monitor;
//factory registration
`uvm_component_utils(wb_monitor)
//constructor
function new (string name=“wb_monitor”,uvm_component parent);
super.new(name,parent);
virtual wb_intf vif; //virtual interface handle
wb_seq_item txn;
uvm_analysis_port #(wb_seq_item) wb_mon_analysis; //analysis port
//build phase
virtual function void build_phase (uvm_phase phase);
super.build_phase (phase);
txn= wb_seq_item::type_id::create(“txn”); //Declare a sequence item handle and create object
wb_mon_analysis = new(“wb_mon_analysis”,this);
if (! uvm_config_db #(virtual wb_intf) :: get (this, “”, “vif”, vif))
`uvm_fatal (get_type_name (), “Didn’t get handle to virtual interface if_name”)
endfunction :build_phase
//RUN PHASE
super.run_phase(phase);
`uvm_info( get_type_name(), “waiting for wishbone seq item sample”, UVM_MEDIUM)
forever begin
@(posedge vif.wb_clk_i);
txn.wb_sel_i=vif.`W_MON.wb_sel_i;
wb_mon_analysis.write(txn);
In reply to kathula venkatesh:
It behaves as you have coded the monitor. And the monitor needs a forever loop. But you do not show the details how you are putting the transaction together.
What is your problem? Does the simulation not come to its end?
yes, simulation is not come to its end, forever inside monitor is continuously executing.
This is an indication something in your monitor is going wrong or it happens somewhere else. Could you please show how you assemble the transaction un the monitor
BTW, seq_items will not be constructed in the build_phase. . They do not belong to the topology of your testbench.
this my sequence
class sl_seq1 extends slave_sequence;
`uvm_object_utils(sl_seq1)
function new (string name=“sl_seq1”);
super.new(name);
spi_seq_item seq;
virtual task body();
seq=spi_seq_item::type_id::create("seq"); //create the seq item
start_item(seq);
	assert (seq.randomize() with {spi_miso inside {[0:1000]};})
	`uvm_info("seq1","seq1 was randomised in between 0 to 1000",UVM_MEDIUM)
finish_item(seq);
endtask :body
endclass :sl_seq1
this is my monitor code
`define MON spi_mon.spi_mon_cb
class spi_monitor extends uvm_monitor;
`uvm_component_utils(spi_monitor)
spi_seq_item txn;
uvm_analysis_port #(spi_seq_item) spi_port;
function new(string name=“spi_monitor”,uvm_component parent);
//super.build_phase(phase);
spi_port = new(“spi_port”,this);
`uvm_fatal (get_type_name (), “Didn’t get handle to virtual spi interface in monitor”)
txn=spi_seq_item::type_id::create(“txn”,this);
uvm_info( get_type_name(), "Going to collect spi seq item sample in monitor", UVM_MEDIUM) forever begin collect_data(); uvm_info( get_type_name(), “spi seq item sample collected in monitor”, UVM_MEDIUM)
spi_port.write(txn);
task collect_data();
//#20;
txn.ss_pad_o=vif.`MON.ss_pad_o;
wait(vif.MON.wb_adr_i=='h10) //CTRL REGISTER ADDRESS begin if(vif.MON.wb_dat_i[8]) //GO_BSY==1
//for lsb=1
if (vif.`MON.wb_dat_i[11]==1) //LSB will go first from miso
	//tx_neg=0 [10](mosi=rising edge) rx_neg=1 [9](miso falling edge)
		if(vif.`MON.wb_dat_i[9]==1 && vif.`MON.wb_dat_i[10]==0)
			if(vif.`MON.wb_dat_i[6:0]==0)  //CHAR LEN==0
			int x=0;
				repeat(128)
				@(negedge vif.`MON.sclk_pad_o)
				txn.spi_miso[x]=vif.`MON.miso_pad_i;
				@(posedge vif.`MON.sclk_pad_o)
				txn.spi_mosi[x]=vif.`MON.mosi_pad_o;
				x++;
			if(!vif.`MON.wb_dat_i[6:0]==0) //CHAR LEN !=0
				for(int i=0;i<vif.`MON.wb_dat_i[6:0];i++)
				txn.spi_miso[i]=vif.`MON.miso_pad_i;
				txn.spi_mosi[i]=vif.`MON.mosi_pad_o;
	//tx_neg=1 [10](mosi= negedge) rx_neg=0 [9](miso posedge)
	if(vif.`MON.wb_dat_i[9]==0 && vif.`MON.wb_dat_i[10]==1)
			int x=0;
				repeat(128)
				x++;
end //LSB=1 end
//if LSB=0
if (vif.`MON.wb_dat_i[11]==0) //MSB will go first from miso
	//tx_neg=0 [10](mosi=posedge) rx_neg=1 [9](miso negedge)
			int x=127;
				repeat(128)
				x--;
				for(int i=vif.`MON.wb_dat_i[6:0];i>0;i--)
	//tx_neg=1 [10](mosi= posedge) rx_neg=0 [9](miso negedge)
			int x=127;
				repeat(128)
				x--;
end //LSB=0 end
end //GO BSY end
end //CTRL end
Could you please paste from your simulation log-file what comes befor the monitor loop.
In collect_data I’d insert a few uvm_infos for debugging use.
