Hi ,
How to write a constraint for 32 bit data to get this type of sequence 100100100…?
I have used $countones but it will randomly set the bit.
Hi ,
In reply to maaroop:
Why do you need to constraint top set something that is not random? And how does that pattern fit into 32-bits?
I want to set the bit in these combination for a packet of data.
1st-4th-7th-10th-13th-16th-19th bit ,
3rd-6th,9th-12th-15th-18th soon
basically I want to set one bit to 1’b1 and then next two bits should be zero.
This is the pattern :32’b0100100100100100100100,
32’b0000100100100100100100100100,
You can use the following constraint, to meet your requirement:
rand bit[31:0] data;
rand int i;
constraint data_c {
i >=0 && i <= 31;
foreach(data[j])
if(j < i) data[j] == 0;
else if(j==i) data[j] == 1;
else if((j-i)%3 == 0) data[j] == 1;
else data[j] == 0;
In reply to S.P.Rajkumar.V:
Thanks Rajkumar
Thanks Dave.
I have one question :
Value is fixed here, can we write one line code to implement like this
000100100100…
0000000001001001001
so, randomly it should pick nth bit.
module tb();
class abc;
rand bit[31:0]data;
constraint c{ foreach(data[i])
if(i%3==0)
data[i]==1;
data[i]==0;
abc d;
initial
d=new();
assert(d.randomize());
$display("value of data =%b",d.data);
$finish;
////////////////////output///////////////////////////////
value of data =01001001001001001001001001001001
Hi ,
module tb();
class rohith;
rand bit[26:0]data;
//constraint k{data[0]=1’b0;}
if(i%3==0)
data[i]==0;
else if(i%3==1)
data[i]==0;
else if(i%3==2)
data[i]==1;
rohith k;
initial
k=new();
assert(k.randomize());
$display(“value of data =%b”,k.data);
$finish;
OUTPUT:value of data =100100100100100100100100100
How about the best of both worlds?
// Code your testbench here
// or browse Examples
module tb();
class abc;
rand bit [2:0] pattern;
bit [31:0] data;
constraint single_bit { $countones(pattern) == 1; }
data = {(33/3){pattern}}; // I'm having trouble explicitly casting to 32 bits, but it still works...
abc d;
d=new();
repeat (10) begin
$finish;
Working example on EDAPlayground
In reply to h2dkb:
Thank you.
