Getting last transaction in consumer repetitively even though producer is sending all transaction
I am sending 5 transactions from producer, in consumer i am getting only last transaction from consumer repetitively. Can some help what can i do to get all transaction in consumer?
This is code below i tried:
`include “uvm_macros.svh”
import uvm_pkg::*;
class my_txn extends uvm_object;
rand int addr;
rand int txn_id;
`uvm_object_utils_begin(my_txn)     `uvm_field_int(addr, UVM_DEFAULT)
`uvm_field_int(txn_id, UVM_DEFAULT)   `uvm_object_utils_end
function new(string name=“my_txn”);
super.new(name);
endclass: my_txn
class my_producer extends uvm_component;
`uvm_component_utils(my_producer)
uvm_analysis_port #(my_txn) analysis_port;
super.new(name, parent);
super.build_phase(phase);
analysis_port = new(“analysis_port”, this);
endfunction : build_phase
my_txn txn;
int tx_cnt;
phase.raise_objection(this);
txn = my_txn::type_id::create(“txn”, this);
repeat(5) begin
void’(txn.randomize());
`uvm_info(get_type_name(), $sformatf(“txn #%0d\n%s”, tx_cnt, txn.sprint()), 	UVM_LOW);
analysis_port.write(txn);
tx_cnt += 1;
phase.drop_objection(this);
endtask:run_phase
class my_consumer extends uvm_component;
`uvm_component_utils(my_consumer)
uvm_analysis_port #(my_txn) analysis_export;
local uvm_tlm_analysis_fifo #(my_txn) analysis_fifo;
analysis_export = new(“analysis_export”, this);
analysis_fifo = new(“analysis_fifo”, this);
virtual function void connect_phase(uvm_phase phase);
analysis_export.connect(analysis_fifo.analysis_export);
int tx_cnt;
#100ns;
//forever begin
repeat(6) begin
my_txn txn;
analysis_fifo.get(txn);
tx_cnt += 1;
endtask:run_phase
endclass: my_consumer
class my_env extends uvm_env;
\`uvm_component_utils(my_env)
my_producer m_producer;
my_consumer m_consumer;
m_producer = my_producer::type_id::create(“m_producer”, this);
m_consumer = my_consumer::type_id::create(“m_consumer”, this);
m_producer.analysis_port.connect(m_consumer.analysis_export);
endfunction : connect_phase
endclass : my_env
\`uvm_component_utils(my_test)
my_env m_env;
m_env = my_env::type_id::create(“m_env”, this);
#100;
module tb_top;
run_test(“my_test”);
Result:
UVM_INFO @ 0: reporter \[RNTST\] Running test my_test...
UVM_INFO testbench.sv(40) @ 0: uvm_test_top.m_env.m_producer \[my_producer\] txn #0
Name      Type      Size  Value
txn       my_txn    -     @463
  addr    integral  32    'hdbbbe251
  txn_id  integral  32    'h3164924f
UVM_INFO testbench.sv(40) @ 0: uvm_test_top.m_env.m_producer \[my_producer\] txn #1
txn       my_txn    -     @463
  addr    integral  32    'he66813cc
  txn_id  integral  32    'h4f69d2ba
UVM_INFO testbench.sv(40) @ 0: uvm_test_top.m_env.m_producer \[my_producer\] txn #2
txn       my_txn    -     @463
  addr    integral  32    'h684cc6c1
  txn_id  integral  32    'hc1876609
UVM_INFO testbench.sv(40) @ 0: uvm_test_top.m_env.m_producer \[my_producer\] txn #3
txn       my_txn    -     @463
  addr    integral  32    'h1532f254
  txn_id  integral  32    'h99d8cefb
UVM_INFO testbench.sv(40) @ 0: uvm_test_top.m_env.m_producer \[my_producer\] txn #4
txn       my_txn    -     @463
  addr    integral  32    'h487120f6
  txn_id  integral  32    'h2df22641
UVM_INFO testbench.sv(76) @ 100: uvm_test_top.m_env.m_consumer \[my_consumer\] txn #0
txn       my_txn    -     @463
UVM_INFO testbench.sv(76) @ 100: uvm_test_top.m_env.m_consumer \[my_consumer\] txn #1
txn       my_txn    -     @463
UVM_INFO testbench.sv(76) @ 100: uvm_test_top.m_env.m_consumer \[my_consumer\] txn #2
txn       my_txn    -     @463
UVM_INFO testbench.sv(76) @ 100: uvm_test_top.m_env.m_consumer \[my_consumer\] txn #3
txn       my_txn    -     @463
UVM_INFO testbench.sv(76) @ 100: uvm_test_top.m_env.m_consumer \[my_consumer\] txn #4
txn       my_txn    -     @463
Please format your code making your code easier for others to read. I have done that for you.
Place the construction of txn within the producer’s repeat loop. Otherwise, you’re placing the same handle into your analysis fifo, effectively overwriting the object it points to.
Thanks dave, it is working.
but i am still not understanding that before keeping txn within producer loop, if i use txn.sprint() we were getting different transactions in producer why it is putting only last transaction in analysis_port.write() method in producer?
You’re not getting different transactions in the producer. You were putting different values into the same transaction, effectively overwriting the previous ones.
This simpler example should demonstrate the concept by using a queue instead of an analysis port for the fifo. In the producer loop, whenever we push a new element onto the queue, we’re simply copying the handle to the object, not a copy of the object itself. Since there’s only one instance of our object, there’s only one place to store values for b.
  class A;
    rand bit [7:0] b;
  A fifo[$];
  initial begin : producer
    A handle;
    handle =new();
    repeat (5) begin
      // handle =new();  // create a new object for each transaction
      assert(handle.randomize());
      fifo.push_back(handle);
      $write("producer--fifo size: %0d ",fifo.size());
      foreach(fifo[i]) $write(" fifo[%0d].b: $h ",i,fifo[i].b);
      $display; // newline
  initial begin : consumer
    A handle;
    forever begin
      wait(fifo.size>0)
      $write("consumer--fifo size: %0d ",fifo.size());
      handle= fifo.pop_front();
When you put the constructor inside the producer loop, now there’s an object to hold each unique set of values.
