please explain the implementation and significance of get_function, get_type_name, get_type function in uvm.
The get() function is a standard OO programming pattern to return an object of a specific type. In UVM, it’s usually used with the uvm_config_db, which is explained the the UVM Cookbook.
The get_type_name() method returns a string with the type name of the object on which it is called.
The get_type() method returns a wrapper of a specific type and is usually used with factory overrides, as explained in the UVM Cookbook.
If you haven’t already done so, I recommend that you view our online video courses:
Basic UVM and Advanced UVM.
Also, please read through the UVM Cookbook. I think you’ll find it valuable.
