Can anyone point me to a collection of generic covergroup definitions that may have been implemented for reuse for purposes like range analysis or other such commonly recurring cases. For instance, for range analysis I’d like something like this, though note that what I have here is a work in progress and is not going to do what I want really becuase there will always be unintended bins that won’t get filled:
Basically, I am working in a plain module-based SV environment, no UVM, few classes, and want to add some functional coverage here and there, but not have to create a dedicated coverage group definition for every covergroup instance I need to cover certain things like value ranges. I’d rather have a collection of generic covergroup definitions to be reused.
Someone, somewhere must have put some of these together (possibly even with the assistance of macros).
Sometimes you have to abandon the desire to express everything in one coverpoint and use an array of covergroups instead.
covergroup cg (ref int v, input int lsb);
option.per_instance=1;
coverpoint v {
bins range = {[int'(lsb>0)<<lsb:(1<<lsb+1)-1]};
endgroup
int width=16;
int signal;
cg cg_inst[];
cg_inst = new[width];
for(int i=0;i<width;i++) begin
$display("Constructng range [%0d:%0d]",int'(i>0)<<i,(1<<i+1)-1);
cg_inst[i] = new(signal,i);
I figured no one better to ask than you, albeit indirectly.
This is a pretty interesting solution indeed. Would not have thought to create an array of covergroups. And I guess by virtue of the (array) name association of each covergroup instance in the array they would still appear in any report in an intuitive manner.
Frankly, I don’t see any other way of going about this, safe perhaps from using (a) “conditional generate” macro(s) to generate the desired covergroup code for the width at hand, so that the macro effectively provides for reuse?
BTW, my code only works with widths up to 30 bits because the largest positive int is 30 bits. To do larger widths, you’ll have to cast both ends of the range to a wider type.
typedef bit [63:0] uint64_t;
covergroup cg (ref uint64_5 v, input int lsb);
coverpoint v {
bins range = {[uint_64_t'(lsb>0)<<lsb:uint64_t'(1<<lsb+1)-1]};
endgroup
