I am trying to write a cover group which can be instantiated per master basis.
Now, this masters can access particular slaves based on the configuration.
I need to write cross coverage of the bins with accessible slaves.
So, I need to ignore slaves which are not accessible for the particular master.
All information is available during compile time.
I am not sure how can I achieve my objective here.
Any help is appreciated.
My sudo code looks like below:
module
class ma_cov extends uvm_component;
// UVM things
covergroup cg();
m_slave: coverpoint slave_list_enum {
bins slvs_b[] = { [ slave_list_enum.first():slave_list_enum.last() ] };
//******** NEED HELP HERE ****************
//Need to write ignore bins here for the slaves which are not accessible for current master
endgroup
cg = new();
cg.set_inst_name(name); // sets the inst name as current master
ma_cov m_cov[string];
string inst_name;
foreach (master_list_enum[i]) begin
inst_name = master_enum_list[i]
m_cov[master_list_enum[i]] = new (inst_name, null);
In reply to chintanm86:
You did not explain how the ma_cov class would know which slaves are to be ignored. However the covergroup feature you want is a bin set expression. You can populate an array with the slaves that are accessible and use the array when declaring the covergroup.
covergroup cg();
option.per_instance = 1;
bins slvs_b[] = { master_slave_list };
endgroup
master_slave_list = // needs to be set before cg construction.
cg = new();
In my env, I have an associative array which contains the master and slave list for that master.
So, its possible to populate another list of slaves which needs to be ignored.
But, if your solution can generate the bins only for the accessible slaves than I dont need ignore_bins anymore.
Just one question:
bins slvs_b = { master_slave_list };
Here,
slave_list_enum is the enum type variable which contains all the slaves.
and master_slave_list is the list containing the slaves which are accessible by current master.
Do I need to declare this master_slave_list as same enum type in this class?
This will generate bins only for list I pass, right?
