Please help me understand the following behaviour related to fork-join_any.
In my environment I have a fork-join_any for the processes:
generator.main();
driver.main();
input_mon.main();
output_mon.main();
checker.main();
join_any
There are two implementation for checker.main(). Both the version only differ from the presence of #10 delay statement within the forever. Following is the code:
task main();
transaction mon1_trans;
transaction mon2_trans; // output monitor
forever
#10; //I inserted a delay here for every iteration. In my another version of this code : this delay is removed.
$display ("the number of generated and monitored transactions are %dand%d ", mon2check.size(), driv2check.size() );
wait(mon2check.size() > 0); //This mon2check is a queue which is filled by the output monitor.
if(mon2check.size() > 0)
if(driv2check.size() > 0)
$display ("WE have both the monitors filled up to hve atleast one element");
mon2check.pop(mon2_trans);
driv2check.pop(mon1_trans);
$display("The input monitor is empty");
So I am facing an issue here - when I don’t add the delay (#10) above in the code - Ideally this task waits for the mon2check size to be greater than 0. This queue gets updated parallelly in the output_mon.main() task (forked with the checker.main()). But though the queue shows that the data is getting filled up , here it just keeps on waiting and the simulation stalls here.
But When I add this delay of #10 - it works perfectly. ****
**What could be the mistake I am doing … Can someone help me to understand if I am missing something.
