Can someone please explain why j = 0 is not printed in this case?
module fork_test1;
for (int j=0; j<3; j++)
$display($time, "#####");
#1;
$display(j);
join_none
endmodule:fork_test1
Thanks!!
module fork_test1;
#1;
$display(j);
join_none
Thanks!!
In reply to ssakshi:
Because the first iteration of the fork does not begin execution until the section iteration hits the #1. j will have already advanced to 1.
module fork_test1;
initial
#1;
automatic int k = j;
$display(j,,k);
join_none
Hi Dave and ssakshi
I was also was a little bit confused after reading Dave answer so I changed the code a little bit to better understand the issue.
In the first code listing I did what did just a little bit different.
module fork_test1;
for (int j=0; j<2; j++) begin
#1;
$display("j before fork %0d", j);
$display("j inside fork-join_none block %0d", j);
join_none
$display("j after join_none %0d", j);
The results were as you saw in the original question
j before fork 0
j after join_none 0
j inside fork-join_none block 1
j before fork 1
j after join_none 1
j inside fork-join_none block 2
In the second code listing, I added delay after the join_none so j will not advance
before fork-join_none starts
module fork_test1;
#1;
join_none
// Add delay
#1;
j before fork 0
j after join_none 0
j inside fork-join_none block 0
j before fork 1
j after join_none 1
Thanks Dave and shimonc!!
I have a follow-up question.
As per LRM,
Fork-join_none: The parent process continues to execute concurrently with all the processes spawned by the fork.The spawned processes do not start executing until the parent thread executes a blocking statement or terminates.
In the above example,
#1 delay before fork-join_none can be treated as a blocking statement to start execution of spawned processes (ie. $display(“j inside fork-join_none”)) or not?
That is correct.
Dave. Again, Does “exit from task” consider as “terminates” ?
In reply to VE:
Calling a task does not create a process, therefore exiting a task does not terminate one. However, every statement in a fork/join block creates a process. When that statement completes, the process terminates. If that statement happens to be a task call, then of course exiting the task call completes the statement, which terminates the process.
This sounds like a silly question but I am still not able to understand if #1 delay before fork-join_none can be treated as a blocking statement to start the execution of spawned processes, then why does display statement after fork-join_none is executed(printed) before the display statement in fork-join_none.
(Why does the spawned process wait until the parent thread terminates?)
As per my understanding, fork-join_none should start execution as soon as the parent thread executes a blocking statement (#1 before fork-join_none).
The rule says “until the parent thread executes a blocking statement or terminates”. This rule eliminates one race condition which allows you to queue up all your forked processes first before allowing them to execute.
It might to explain what’s going on by unrolling the for-loop from shimonc’s first example.
module fork_test1;
int j;
j = 0;
#1;
join_none
j++;
#1; // this triggers the previous fork/join j is now 1
join_none
j++;
#1; // this triggers the previous fork/join j is now 2
join_none
j++;
end // initial process terminates, triggers the previous fork/join j is now 3
Thank you Dave for the detailed explanation.
module fork_test1;
initial
#1;
$display(j,,k);
join_none
Thanks for the explanation. But I made a small change in the above code :
module fork_test1;
initial
#1;
$display(j,,k);
join_none
Now too will it display
1
2
3
In reply to SanjanaDhiran:
It should display:
0#####
1#####
1
2#####
2
3
Explanation:
Below Sequence will be followed-
Irshad
I came across a similar question
module t;
initial
$display("%0t main thread started",$time);
print(20,"thread_0");
print(10,"thread_2");
print(15,"thread_1");
join_none
$display("%0t main thread finished",$time);
task print(int time_t,string t_name);
#(time_t)$display("[%0t] %s",$time,t_name);
the output is
0 main thread started
0 main thread finished
[10] thread_1
[15] thread_1
[20] thread_1
but when code is modified to
module t;
initial
join_none
$display("[%0d] %s",time_t,t_name);
i got output as
[20] thread_0
[10] thread_2
[15] thread_1
In both examples, task is static. can you please help
In reply to roopatoms:
In the both examples, there is only one t_name static variable.
In the first example, by the time the $display executes, t_name has be assigned three times, so it display whatever the last value was. That is a race condition, any you could have seen any of the three thread names three times.
In the second example, there is no delay inside the print task. So there is a race condition between execution of calling all print tasks and the $display statement. It just happens that each task gets called and executes $display before calling the next task in another thread. Technically it’s possible to get the same output as the first example if after calling the print task, it suspends the thread and jumps to the next thread before calling $display.
Thank you Dave. The topic was confusing for me.
Hi Dave, In the first example by @roopatoms, I understand why t_name gets overwritten since t_name is a static variable. Why isn’t time_t a static variable as well? time_t is also just an argument to the task similar to t_name in this case.
[10] thread_1
[15] thread_1
[20] thread_1
Since thread1 seems to have been the last executed in this case, shouldn’t all tasks be delayed by the last time_t (15) instead of variable delay?
In reply to svq:
t_name and time_t are both static variables, and this is a race condition. When executing
#(delay), the delay expression gets evaluated first, then the process gets suspended for the delay value amount of time. If the operands of the delay expression later change while the process is suspended, the expression does not get re-evaluated.
Technically it’s possible for one of the task to get called in one process and then immediately switch to another process that calls the same task again and overwrites the arguments. But usually a process runs uninterrupted until hitting a blocking statement.
Thanks Dave.
In the above code, below statement gets executed immediately i.e. does not wait for #1 scenario of the next iteration.
Is this because of the below reason mentioned in LRM?
LRM:
Variables declared in the block_item_declaration of a fork-join block shall be initialized to their
initialization value expression whenever execution enters their scope and before any processes are spawned.
In reply to kuki2002:
That is correct. Actually for this example, it would have made no difference if the automatic variable declaration was moved out of the fork block. Each iteration of the for-loop creates a new scope activation and another instance of the automatic variable k.
module fork_test1;
initial
#1;
$display(j,,k);
join_none
