Thank you Dave for the detailed explanation.
Thanks Dave and Subramaniam the concept of fork join_none was very useful.
Hi Dave ,
For The Following Code
for( int j = 1; j <= 3; ++j )
fork
automatic int m = j; // the value of m is undetermined
#k $write( "%0d", k );
join_none
The LRM Says the Value of m is undetermined . Why is That so ?
In reply to Etrx91:
This is an error in the LRM. See 0004176: erroneous comment in example of fork-end block? - Accellera Mantis
hello Dave sir, i got the concept what you have explained above but I have a small doubt
I have implemented the following code
module fork_test;
initial
for (int j=0; j<3; j++)
automatic int k=j;//(1)
fork
//automatic int k=j;//(2)
$display(k,$time );
join_none
I got the result i=3 thrice … i would like to know as I have put condition on i in for loop that it should be less than 3 still why its coming i =3.
another thing is when i implements number (1) statement it display result 2,1,0 why in reverse order? while for(2) it comes in order 0,1,2. I have run this code in EDA tool cadence incisive 15.20
thanks and regards
In reply to suman_vip:
I also ran this code on EDA playground and did not see the results you are getting. However, the order the $display statements execute is indeterminate.
There is no “i” in your example. But if you meant you were displaying “j” inside the fork/join_none loops, then j would be 3 since the for loop would terminate before any statements within the fork/join_none starts executing. That’s the point of giving each iteration of the for loop a local copy of k.
sorry sir , my mistake it was “j” .thanku sir
for(j=0;j<3;j++)
as per i understand , for loop will be suspended whenever j exceeds 2 ie if j=3 loop suspended but if i will display j it will show 3 is it so sir.
Hello Dave,
While going through this informative post. I had a question related to lifetime of control variable of for-loop.
initial
for(int j=1; j<=3; j++)
fork
automatic int k = j;
#k $write($time,"k=%0d\n",k);
automatic int m =j;
$display("m=%0d",m);
join_none
#100;
I want to understand the lifetime of j in this example. for-loop execution will get over at time zero and it will schedule 6 process which will spawn once simulator hit #100.
In above example j is available(m=j) irrespective of for-loop execution is over. Does that means j lifetime is also dependent on the process which are schedule while for-loop is executing ?
In reply to gauravsi:
The lifetime of any automatic variable ends when the life of its block and all its nested blocks ends.
Hi Dave,
I have a question in mind, how does this piece of code or logic suitable for clock-based and event based simulations.
I am particularly looking for to understand clock-based simulation on above explained code by you.
Can you give some information.
sreeni.
In reply to nivas:
It’s hard to answer your question because this is a long thread of responses and there’s no clock in any of these examples. Perhaps you should try asking as a new question.
I have a doubt :
module fork_test1;
#1;
fork
$display(j);
join_none
endmodule:fork_test1
the output for the above code is :
1
2
3
Why is that> Why it is not printing 0?
In reply to SanjanaDhiran:
https://verificationacademy.com/forums/systemverilog/fork-joinnone-delay#reply-93311
What is the difference between the following 2 codes:
code 1:
for (int i = 0; i<3;i=i+1) begin
fork
automatic int k = i;
$display(k);
join_none
Code 2:
fork
$display(k);
join_none
There is no functional difference between the two codes you show. An instance of k gets created for each iteration of the for loop, and the lifetime of each k ends when the statement containing the $display finishes.
The only difference would be seen if there were more code inside the begin/end block. In code 1, the visibility of k is limited to inside the fork/join_none block.
Hello Dave, I modified the code. Now, send is not automatic .why it still displays driving 0,1,2… instead of driving 15,15,15,15…?
Thanks
module test;
for(int i = 0; i < 16; i++)
fork
automatic int index =i ;
send(index);
join_none
wait fork;
function send( int j);
$display("driving %0d %t" , j, $realtime);
endfunction /
In reply to peter:
Because sand() is a function executing with no delays. In theory it’s possible for an iteration of a process to call send() and then switch to another process before executing the $display statement. But in practice, you will never see that happen on a single core simulation.
Hi Dave, sixteen send function should be executed parallelly according to the spec. If the
result shows 15,15,15,15… The result should satisfy the spec?
You mention that it’s possible for an iteration of a process to call send() and then switch to another process before executing the $display statement. it seems that it is different with the spec, because send is running sequential instead of parallel. Would you explain more about never see that happen on a single core simulation?
Thank you!!
