Thanks Dave !!
I have a question in mind, how does this piece of code or logic suitable for clock-based and event based simulations.
I am particularly looking for to understand clock-based simulation on above explained code by you.
Can you give some information.
sreeni.
In reply to nivas:
It’s hard to answer your question because this is a long thread of responses and there’s no clock in any of these examples. Perhaps you should try asking as a new question.
I have a doubt :
module fork_test1;
for (int j=0; j<3; j++)
#1;
$display(j);
join_none
endmodule:fork_test1
the output for the above code is :
1
2
3
Why is that> Why it is not printing 0?
In reply to SanjanaDhiran:
https://verificationacademy.com/forums/systemverilog/fork-joinnone-delay#reply-93311
What is the difference between the following 2 codes:
code 1:
for (int i = 0; i<3;i=i+1) begin
automatic int k = i;
$display(k);
join_none
Code 2:
$display(k);
join_none
There is no functional difference between the two codes you show. An instance of k gets created for each iteration of the for loop, and the lifetime of each k ends when the statement containing the $display finishes.
The only difference would be seen if there were more code inside the begin/end block. In code 1, the visibility of k is limited to inside the fork/join_none block.
Hello Dave, I modified the code. Now, send is not automatic .why it still displays driving 0,1,2… instead of driving 15,15,15,15…?
module test;
for(int i = 0; i < 16; i++)
automatic int index =i ;
send(index);
join_none
wait fork;
function send( int j);
$display("driving %0d %t" , j, $realtime);
endfunction /
In reply to peter:
Because sand() is a function executing with no delays. In theory it’s possible for an iteration of a process to call send() and then switch to another process before executing the $display statement. But in practice, you will never see that happen on a single core simulation.
Hi Dave, sixteen send function should be executed parallelly according to the spec. If the
result shows 15,15,15,15… The result should satisfy the spec?
You mention that it’s possible for an iteration of a process to call send() and then switch to another process before executing the $display statement. it seems that it is different with the spec, because send is running sequential instead of parallel. Would you explain more about never see that happen on a single core simulation?
Thank you!!
