Fork/join inside for loop
Hello,
I’m trying multiple forloops and forking inside them. Running into hang issue. Could someone suggest what I’m doing wrong ?
I also apologize for the indentation issues below. Looks fine when I type it, but looses all the coding indentation later.
   forever begin : resetloop
      wait(drv_rst_state==RESET_INACTIVE);
      fork : resetloop_fork
        for (int i = 0; i < 16; i++) begin
          automatic int j;
          j = i;
              main_error_injection_loop(j);
          join_none
          automatic int j;
          j = i;
              event_gen_loop(j);
          join_none
          wait(drv_rst_state==amd_reset_uvc_pkg::RESET_ACTIVE);
      join_any
      disable resetloop_fork;
    end // block: resetloop
Thanks!
In reply to noel_sumners:
When are you ending this outer process?
I don’t need to end that one. It is inside a forever loop and it waits for reset to deassert before forking off the threads. When reset asserts, we disable the forked loops.
But something is messed-up with my forked loops.
The point is, code might be ‘never ending’ because you don’t have any conditions to disable the forever loop.
Also,
  // Process 1
  join_none
  // Process 2
  join_none
  // Process 3
  // You will encounter join_any statement as
  // Process 1 and 2 finishes immediately.
  join_any
You can use code tags when posting your code. I have added them for you.
Since your for-loops execute with 0 delay, the join_any happens immediately, never waiting for RESET_ACTIVE. I suggest simplifying your code and writing the loop as follows:
      fork begin : body
            automatic int j; = i
          join_none
            automatic int j = i;
            event_gen_loop(j);
          join_none
        disable fork;
      end : body join
    end : resetloop
I discourage the use of disabling named blocks. label names are not re-entrant. If you have multiple activation of this code,( i.e. from multiple instances of a class object) the disable affects all instances. Use disable fork instead.
Thanks Dave! That worked like a charm!! And thanks for the “code tags” pointer. Will use in future.
Thanks Mayur for your comment too!
