As we all know that in our UVM based verification environment in TOP there is a DUT and under this Test will Come. Now If we want to force the DUT signal from test without using Interface, can some explain me how can we achieved this.
Thanks Dave. But need more clarification as in your paper we are still using the interface for DUT signal.
Suppose i want to force the dut signal as:
signal name is reset_b;
Model name is adder;
signal reside in added.adder_1.
so if we want to force the signal from test case we can used this as:
force (“adder.adder_1.reset_b”, 1’b0")
In reply to yuvraj khare:
You can’t use a string to represent a hierarchical path. You can use an interface or module with a bind statement to connect to the DUT signal as the paper shows using the bind statement. Instead of a set/get_probe method, you can have a force method that testbench can call.
Thanks Dave.
