I want to set the address map for the ACE questaVIP
Here I have four diffrent slaves.The address width is 64 bit.
Address[6:5] decides the slave ie. if address[6:5]==0 then it is for slave0, if address[6:5]==1 then it is for slave1, and so on.
I want to set address map for address range 64’h8000_0000 to 64’hFFFF_FFFF
So considering above condition
64’h8000_0000 is the starting address of slave0; ie size of 'h20
64’h8000_0020 is the starting address of slave1 ie size of 'h20
64’h8000_0040 is the starting address of slave2 ie size of 'h20
64’h8000_0060 is the starting address of slave3 ie size of 'h20
Again
64’h8000_0080 is the starting address of slave0; ie size of 'h20
64’h8000_00a0 is the starting address of slave1; ie size of 'h20 and so on
So I have written this using for loop.But the compilation taking vary very long time.
Is there any way to speed the compilation. or any ther logic to do this task?
// code here ‘i’ is used for starting address
for (longint i='h8000_0000; i <'hFFFF_FFFF;i=i+‘h80)begin
addr_map.add(’{MAP_NORMAL,“S0”,0,MAP_SI,10,i,'h0000_0020,MEM_NORMAL,MAP_NORM_SEC_DATA});//slave0
for (longint i='h8000_0020; i <'hFFFF_FFFF;i=i+‘h80)begin
addr_map.add(’{MAP_NORMAL,“S0”,1,MAP_SI,10,i,'h0000_0020,MEM_NORMAL,MAP_NORM_SEC_DATA});//slave1
for (longint i='h8000_0040; i <'hFFFF_FFFF;i=i+‘h80)begin
addr_map.add(’{MAP_NORMAL,“S0”,2,MAP_SI,10,i,'h0000_0020,MEM_NORMAL,MAP_NORM_SEC_DATA});//slave2
for (longint i='h8000_0060; i <'hFFFF_FFFF;i=i+‘h80)begin
addr_map.add(’{MAP_NORMAL,“S0”,3,MAP_SI,10,i,'h0000_0020,MEM_NORMAL,MAP_NORM_SEC_DATA});//slave3
Thanks,
