For loop taking large compilation time
I want to set the address map for the ACE questaVIP
Here I have four diffrent slaves.The address width is 64 bit.
Address[6:5] decides the slave ie. if address[6:5]==0 then it is for slave0, if address[6:5]==1 then it is for slave1, and so on.
I want to set address map for address range 64’h8000_0000 to 64’hFFFF_FFFF
So considering above condition
64’h8000_0000 is the starting address of slave0; ie size of 'h20
64’h8000_0020 is the starting address of slave1 ie size of 'h20
64’h8000_0040 is the starting address of slave2 ie size of 'h20
64’h8000_0060 is the starting address of slave3 ie size of 'h20
Again
64’h8000_0080 is the starting address of slave0; ie size of 'h20
64’h8000_00a0 is the starting address of slave1; ie size of 'h20 and so on
So I have written this using for loop.But the compilation taking vary very long time.
Is there any way to speed the compilation. or any ther logic to do this task?
// code here ‘i’ is used for starting address
for (longint i='h8000_0000; i <'hFFFF_FFFF;i=i+‘h80)begin
addr_map.add(’{MAP_NORMAL,“S0”,0,MAP_SI,10,i,'h0000_0020,MEM_NORMAL,MAP_NORM_SEC_DATA});//slave0
for (longint i='h8000_0020; i <'hFFFF_FFFF;i=i+‘h80)begin
addr_map.add(’{MAP_NORMAL,“S0”,1,MAP_SI,10,i,'h0000_0020,MEM_NORMAL,MAP_NORM_SEC_DATA});//slave1
for (longint i='h8000_0040; i <'hFFFF_FFFF;i=i+‘h80)begin
addr_map.add(’{MAP_NORMAL,“S0”,2,MAP_SI,10,i,'h0000_0020,MEM_NORMAL,MAP_NORM_SEC_DATA});//slave2
for (longint i='h8000_0060; i <'hFFFF_FFFF;i=i+‘h80)begin
addr_map.add(’{MAP_NORMAL,“S0”,3,MAP_SI,10,i,'h0000_0020,MEM_NORMAL,MAP_NORM_SEC_DATA});//slave3
In reply to navinpatil1:
I can’t see how this code would take long to compile. Simulation would take millions of iterations. Are you sure that is what you want to do?
It’s my mistake,the simulation is taking time not compilation. Is there any approach to speed up this. Because only after this configurations,my actual tests will start.
Do you really have millions of slaves?
No, have only four slaves, But as as mentioned previously the [6:5] bits of address decides the slaves. So it divides the whole 64 bit address into multiple address ranges of size ‘h20.
The addr_map.addr requires the parameters like slave_id(ie. 0 for slave0, 1 for slave1 etc.), starting_address, size_of_address_range (end_address=starting_addr+size-1)
So eg. For slave0 there will be multiple entries with
1)Starting_address :‘h8000_0000 size:’h20 slave_id:0
2)Starting_address :’h8000_0080 size:’h20 slave_id:0 (here starting address is ‘h8000_0080 because ‘h8000_0020 to ‘h8000_0080 is for slave 1 to 3 depending on [6:5] bits).
So I need to write multiple entries for each slave considering different starting_address .
