Flow after run_test() is executed
Hi all,
I am getting an error like Error (suppressible): (vsim-3601) Iteration limit 10000000 reached at time 0 ns.
By just running the UVM testbench am getting above mention error and no DUT is attached to it. if i get to know the flow then it may help in debugging it.
In reply to anilhr:
I assume that you have somewhere an endless loop which consumes some delta cycles. I obtained the same error with this example:
`include "uvm_macros.svh"
import uvm_pkg::*;
   `uvm_component_utils(my_test);
   function new(string name = "", uvm_component parent);
      super.new(name, parent);
      phase.raise_objection(this, $sformatf("Start of test: %s", get_name()));
      forever begin
         #0;
      run_test("my_test");
Can you confirm that your code contains such a loop?
Best regards,
Cristi
In reply to Cristian_Slav:
my test is more complicated than above code, But yes i have forever loops in my code.
In reply to anilhr:
Try to look in those loops to make sure they consume simulation time.
What I usually do in this situation is stop the simulator and print the call stack. Then you’ll see in which loop you’re stuck. You’ll have to look in the manual to see how to show the call stack.
