I have to open few files randomly from the test case. If i choose to pass the paths of those files through a environment variable, how can i operate on those files. Below is the way i am doing,
Ex:
//assigning path to a variable
env_var= a/b/abc.txt
//in testcase
file=$getenv(env_var);
$fopen(); and other tasks
Am i doing the right way. If this can be done using any other method please share it here.
Thanks.
In reply to Sravan Reddy k:
$getenv is not part of any standard Some tool or someone would have to provide it as a PLI application. But since getenv() is pard of the C standard library, you can import it into SV.
import "DPI-C" function string getenv(input string env_name);
string HOME;
HOME = getenv("HOME");
$display("$HOME = %s\n", HOME) );
Can this approach be used to access an env variable in `include to access different paths rather then hard-coding them ?
Something like :
`include “{getenv(HOME)/abc.sv”
In reply to sjain12:
No. Compiler directives get processed before executing any SystemVerilog code.
But since file pathnames are specific to the OS/platform your tool runs on, you may be able to write
`include "${HOME}/abc.sv"
You’ll need to check your tool’s user manual or contact them for support.
