Fibonacci Series with negative numbers
Hello all! I’m trying to print fibonacci series with negative numbers. Here is the code:
class fibonacci_series;
	real term_fib_1;
	real  term_fib_2;
	int terms_total_fib;
	real term_fib_sum;
	int i;
		function void terms_needed(real term_fib_1 = -3 , real term_fib_2 = -8 , int terms_total_fib = 10);
			$display("\nTerms are term_fib_1 = %0d and term_fib_2 = %0d",term_fib_1,term_fib_2);
			$display("\nThe number of terms needed in the fibonacci series are %0d", terms_total_fib);
		endfunction: terms_needed
		task operation_fibonacci(real term_fib_1 = -3, real term_fib_2 = -8 , terms_total_fib = 10);
			for(i=1;i<=terms_total_fib;i++)
					term_fib_sum = term_fib_1 +  term_fib_2;
					term_fib_1   = term_fib_2;
					term_fib_2   = term_fib_sum;
					$display("\n%0d",term_fib_sum);
		endtask: operation_fibonacci
endclass: fibonacci_series
module fibonacci_series_using_class;
	fibonacci_series f;
			f = new();
			f.terms_needed;
			f.operation_fibonacci;
O/P I got:
Terms are term_fib_1 = 4294967293 and term_fib_2 = 4294967288
# The number of terms needed in the fibonacci series are 10
# The required Fibonacci Series with 0 terms is
# 4294967285
# 4294967277
# 4294967266
# 4294967247
# 4294967217
# 4294967168
# 4294967089
# 4294966961
# 4294966754
# 4294966419
How do I rectify this? Thank you in advance.
In reply to Shashank Gurijala:
Please, Please use code tags making your code easier to read. I have added them for you several times.
Your problem is the formatting of the $display statement. The LRM says that the %d format specifier may only be used with integral arguments; you are using real numbers. Use %g instead.
