Hi sir/mam
I have done spi master core compile all file,simulation also done ,but give fatal errors ater run the code ,
bellow transcript window display given error mentioned ,
please suggest me
** Fatal: (vsim-131) scb_spi.sv(21): Null instance encountered when dereferencing ‘/top_env_spi_sv_unit::scoreboard::run/this*.gen_scb’
Time: 0 ps Iteration: 1 Process: /top_env_spi_sv_unit::environment::run_env/fork#43_ff03d53 File: scb_spi.sv
Fatal error in Task top_env_spi_sv_unit/scoreboard::run at scb_spi.sv line 21
HDL call sequence:
Stopped at scb_spi.sv 21 Task top_env_spi_sv_unit/scoreboard::run
called from env_spi.sv 43 Task top_env_spi_sv_unit/environment::run_env
Thanks in advance
