Facing Error while using UVM Pack Method
I am facing this error while using uvm pack method
** Error: trans.sv(41): The actual (this.packed_data) and formal (bitstream) for a ref must be equivalent types.
** Error: trans.sv(45): The actual (this.packed_data) and formal (bitstream) for a ref must be equivalent types.
Here my code
module exp;
  `include "uvm_macros.svh"
  import uvm_pkg::* ;
  class ethernet_trans extends uvm_sequence_item;
    bit [55:0] preamble = 'b10101010_10101010_10101010_10101010_10101010_10101010_10101010;
    bit [7:0] sfd = 'b10101011;
    rand bit [47:0] destination_address, source_address;
    rand bit [15:0] length;
    rand byte unsigned data_q [$];
    bit[127:0] packed_data [];
    bit [31:0] fcs = 'h0000_0000;     //initially 00
    constraint data_size_c {data_q.size == length;}
    constraint length_c {length <= 1500;
                        length >= 46;}
    constraint size_len_c { solve length before data_q.size;}
    `uvm_object_utils_begin(ethernet_trans)
      `uvm_field_int(preamble, UVM_ALL_ON | UVM_NOPACK)
      `uvm_field_int(sfd, UVM_ALL_ON | UVM_NOPACK)
      `uvm_field_int(destination_address, UVM_ALL_ON | UVM_NOPACK)
      `uvm_field_int(source_address, UVM_ALL_ON | UVM_NOPACK)
      `uvm_field_int(length, UVM_ALL_ON | UVM_NOPACK)
      `uvm_field_queue_int(data_q, UVM_ALL_ON | UVM_NOPACK)
      `uvm_field_int(fcs, UVM_ALL_ON | UVM_NOPACK)
    `uvm_object_utils_end
    function void fcs_calc();
      void'(pack(packed_data));       //for fcs calculation     //Error in this line
      foreach(packed_data[i]) begin
        fcs = packed_data[i] ^ 'h82608edb;       //'h82608edb
      void'(pack(packed_data));       //final packet for transfer //Error in this line
    function void post_randomize;
      fcs_calc;
    virtual function void do_pack(uvm_packer packer);
      super.do_pack(packer);
      packer.pack_field(destination_address, $bits(destination_address));
      packer.pack_field(source_address, $bits(source_address));
      packer.pack_field(length, $bits(length));
      foreach(data_q[i])
        packer.pack_field(data_q[i],8);
      packer.pack_field(fcs, $bits(fcs));
    function new(string name ="ethernet_trans");
      super.new(name);
  endclass : ethernet_trans
  ethernet_trans packet;
    packet = new;
    assert(packet.randomize());
    foreach(packet.packed_data[i]) begin
      `uvm_info("PACK",$sformatf("bit_packed_data[%0d] = %b",i,packed_data[i]),UVM_LOW)
Thanks in Advance
In reply to Bharat.manvani:
The uvm_object::pack() method requires an argument variable whose type is a dynamic array of a single bit, not a packed array of 128 bits. .
Hi @dave_59
Can you please check this
module exp;
`include “uvm_macros.svh”
import uvm_pkg::* ;
:white_check_mark: bit[127:0] packed_data ; ////// it’s already bit type and dynamic
                    length >= 46;}
  fcs_calc;
  foreach(data_q[i])
  super.new(name);
packet = new;
`uvm_info(“PACK”,$sformatf(“bit_packed_data[%0d] = %b”,i,packed_data[i]),UVM_LOW)
It needs to be a packed array of a single bit.
