I see good example on verification academy: https://verificationacademy.com/verification-horizons/june-2012-volume-8-issue-2/On-the-Fly-Reset on how to handle reset. Can someone point me any example or psuedo code for writing a reset sequence. Since reset will be part of virtual interface how can we control and write a separate sequence?
In reply to curious_verifier:
Writing a separate sequence for handling resets in a UVM environment involves creating a sequence that specifically targets reset scenarios. Below is a pseudo-code example illustrating how you can approach writing a reset sequence in UVM:
class ResetSequence extends uvm_sequence#(some_transaction_type);
// Define necessary variables or configurations
// Constructor
function new(string name = "ResetSequence");
super.new(name);
// The main body of the reset sequence
task body();
// Optional: Add any pre-reset actions
// Send a reset command to the DUT (assume reset_command is a sequence item)
`uvm_do_with(reset_command, {
.reset_type = RESET_ASSERT; // or RESET_DEASSERT for deassert
// Add any specific reset-related configuration if needed
// Optionally, wait for acknowledgment or check status
// Optional: Add any post-reset actions
// Optionally, wait for some duration after the reset
#10;
// Other sequence items or actions after reset if needed
// End of sequence
`uvm_sequence_utils(finish_sequence)
In this pseudo-code:
some_transaction_type is a placeholder for the actual transaction type you are using in your environment.
The reset_command is assumed to be a sequence item representing a reset command. You need to define this sequence item based on your DUT’s protocol.
The reset_type field in the reset_command specifies whether it’s an assert or deassert type of reset.
The optional sections labeled “Optional: Add any pre-reset actions” and similar provide spaces where you can customize the sequence to include any setup or cleanup actions before or after the reset.
The #10 delay after the reset is optional and can be adjusted based on your requirements.
To use this sequence in a test, you would typically call it from your test’s main function or another sequence. For example:
class MyTest extends uvm_test;
// ... other test components ...
ResetSequence reset_seq;
// Create an instance of the reset sequence
reset_seq = ResetSequence::type_id::create("reset_seq");
// Start the reset sequence
`uvm_create(reset_seq)
`uvm_sequence_start(reset_seq)
// Continue with other sequences or actions after the reset if needed
This example provides a basic structure for a reset sequence. You may need to adapt it to fit the specifics of your DUT, your verification environment, and your desired reset handling strategy.
rahulvala@gmail.com
Freelancer/verification engineer
https://www.linkedin.com/in/rahulvala/
