[Q1] Can I state that eg2 is an example of multi-clocked sequence that is used as a multi-clocked property ?
On trying the following multiclocked expression
// What is the LHS of 'and' ? Is it @(posedge clk1) b [ OR ] @(posedge clk0) a ##1 @(posedge clk1) b ?
eg3:assert property( @(posedge clk0) a ##1 @(posedge clk1) b and @(posedge clk2) c );
I expected that leading clock would be clk0 and then at the nearest subsequence posedge of clk1 / clk2 there would be an ‘and’ operation, however I observe a compilation error.
[Q2] Is the error because the LHS of ‘and’ operator is @(posedge clk0) a ## 1 @(posedge clk1) b ?
Since ‘and’ / ‘or’ / ‘intersect’ operators are illegal for multiclocked sequences , the code is termed illegal.
Note : One solution for eg3 is to replace ## 1 with followed-by property operator ( #=# / #-# )
[Ben] YES
[Q1] On trying the following multiclocked expression
// What is the LHS of ‘and’ ? Is it @(posedge clk1) b [ OR ]
// @(posedge clk0) a ##1 @(posedge clk1) b ?
[Ben] I see it as
(@(posedge clk0) a ##1 @(posedge clk1) b) and
(@(posedge clk2) c );
There is no singly clock to both properties that must start at the same leading clocking event.
[Ben] The following works
// ( @(posedge clk0) a ##1 @(posedge clk1) b and @(posedge clk2) c );
eg3_ok:assert property(@(posedge clk0) 1 |->
(@(posedge clk2) c));
(@(posedge clk0) 1 ##0 @(posedge clk2) c));
The error message differs across tools. Some treat it as multi-clocked sequence and throw an error for invalid ‘and’ operator used in a multi-clocked sequence while only one tool correctly identifies the issue as absence of leading clock.
