module break_continue;
initial
bit [1024:0] cmd;
int x;
int c;
x = $fopen("test.txt");
$display("x=%d",x);
while(!($feof ( x )))
c=$fscanf(x,"%s",cmd);
$display("cmd=%s",cmd);
case(cmd)
" " : continue;
"done": break;
endcase
$fclose(x);
In above code at simulation below errors are coming, please help
$feof : Argument 1 is not a valid file descriptor.
$fscanf : Argument 1 is not a valid file descriptor.
In reply to DVEngineer:
Do you know if the file opened successfully? Use $ferror to find out.
The file is successfully opening.
x value printing as 2.
initial
bit [1024:0] cmd;
int x;
int c;
$display("x=%d",x);
case(cmd)
" " : continue;
"done": break;
endcase
$fclose(x);
x = $fopen(“test.txt”,“r”); //specify mode while opening file.
