Error on sequencer - send_request failed to cast sequence item
I build a uvm testbench using RAL to understand the concept of the abstraction layer, but when i run the simulation i have a UVM_FATAL at my sequencer.
UVM_FATAL @ 10: uvm_test_top.m_env.m_agent.m_seqr [m_seqr] send_request failed to cast sequence item
I try to understand the error and i think is a failing cast operation between the sequence_item and the uvm_reg_bus_op, but i can’t fix the error. Some of the code is below and the link to Github containing all code is UVM-APB_RAL
class reg2apb_adapter extends uvm_reg_adapter;
   `uvm_object_utils (reg2apb_adapter)
   function new (string name = "reg2apb_adapter");
      super.new (name);
   virtual function uvm_sequence_item reg2bus (const ref uvm_reg_bus_op rw);
      apb_tr tr = apb_tr::type_id::create ("tr");
      tr.write = (rw.kind == UVM_WRITE) ? 1: 0;
      tr.addr  = rw.addr;
      tr.data  = rw.data;
      `uvm_info ("adapter", $sformatf ("reg2bus addr=0x%0h data=0x%0h kind=%s", tr.addr, tr.data, rw.kind.name), UVM_DEBUG)
      return tr;
   virtual function void bus2reg (uvm_sequence_item bus_item, ref uvm_reg_bus_op rw);
      apb_tr tr;
      if (! $cast (tr, bus_item)) begin
         `uvm_fatal ("reg2apb_adapter", "Failed to cast bus_item to tr")
      rw.kind = tr.write ? UVM_WRITE : UVM_READ;
      rw.addr = tr.addr;
      rw.data = tr.data;
      `uvm_info ("adapter", $sformatf("bus2reg : addr=0x%0h data=0x%0h kind=%s status=%s", rw.addr, rw.data, rw.kind.name(), rw.status.name()), UVM_DEBUG)
class traffic_env extends uvm_env;
   `uvm_component_utils (traffic_env)
   ral_block_traffic_cfg          m_ral_model;         // Register Model
   uvm_reg_predictor #(apb_tr)    m_apb2reg_predictor; // Map APB tx to register in model
   apb_agent                      m_agent;             // Agent to drive/monitor transactions
   traffic_scoreboard             m_scoreboard;        // Scoreboard
   function new (string name = "traffic_env", uvm_component parent);
      super.new (name, parent);
   virtual function void build_phase (uvm_phase phase);
      super.build_phase (phase);
      m_agent = apb_agent::type_id::create ("m_agent", this);
      m_ral_model          = ral_block_traffic_cfg::type_id::create ("m_ral_model", this);
      m_ral_model.build();
      m_apb2reg_predictor  = uvm_reg_predictor #(apb_tr)::type_id::create("m_apb2reg_predictor", this);
      m_scoreboard = traffic_scoreboard::type_id::create("jb_fc_sub", this );
      uvm_config_db #(ral_block_traffic_cfg)::set (null, "uvm_test_top", "m_ral_model", m_ral_model);
      uvm_reg::include_coverage ("*", UVM_CVR_ALL);
   virtual function void connect_phase (uvm_phase phase);
      super.connect_phase (phase);
      m_agent.ag_ap.connect(m_scoreboard.apb_export);
      m_ral_model.reg_map.set_auto_predict(0);
      m_ral_model.reg_map.set_sequencer(m_agent.m_seqr, m_agent.reg2apb);
      m_apb2reg_predictor.map       = m_ral_model.reg_map;
      m_apb2reg_predictor.adapter   = m_agent.reg2apb;
      m_agent.ag_ap.connect(m_apb2reg_predictor.bus_in);
      m_scoreboard.m_ral_model = m_ral_model;
class my_sequence extends uvm_reg_sequence();
   `uvm_object_utils (my_sequence)
   function new (string name = "my_sequence");
      super.new (name);
   virtual task body ();
      uvm_reg_data_t rdata;
      uvm_status_e   status;
      int            reg_idx = 1;
      $cast(m_ral_model, model);
      write_reg(m_ral_model.ctrl, status, 32'd3);
      write_reg(m_ral_model.timer[0], status, 32'b00000010000000000000100000000001);
      write_reg(m_ral_model.timer[1], status, 32'd0);
      read_reg(m_ral_model.timer[1], status, rdata );
class apb_agent extends uvm_agent;
   `uvm_component_utils (apb_agent)
   uvm_analysis_port #(apb_tr) ag_ap;
   apb_driver                  m_drvr;
   apb_monitor                 m_mon;
   reg2apb_adapter             reg2apb;
   uvm_sequencer #(apb_tr)     m_seqr;
   function new (string name="apb_agent", uvm_component parent);
      ag_ap = new("ag_ap", this);
      m_seqr = uvm_sequencer#(apb_tr)::type_id::create ("m_seqr", this);
      m_drvr = apb_driver::type_id::create ("m_drvr", this);
      m_mon = apb_monitor::type_id::create ("m_mon", this);
      reg2apb = reg2apb_adapter::type_id::create("reg2apb", this);
      m_drvr.seq_item_port.connect(m_seqr.seq_item_export);
      m_mon.mon_ap.connect(ag_ap);
class base_test extends uvm_test;
   `uvm_component_utils (base_test)
   traffic_env             m_env;
   function new (string name = "base_test", uvm_component parent);
      m_env = traffic_env::type_id::create ("m_env", this);
      m_ral_model = ral_block_traffic_cfg::type_id::create("jb_reg_block");
      m_env.m_ral_model = m_ral_model;
//      factory.set_type_override_by_type(ral_sample1::get_type(), my_sample::get_type());
//      factory.print();
   virtual task reset_phase (uvm_phase phase);
      super.reset_phase (phase);
      phase.raise_objection (this);
      phase.drop_objection (this);
   virtual task main_phase (uvm_phase phase);
Thanks.
In reply to Jose_Iuri:
The interesting thing is your register adapter does not appear in the object browser. I did not investigate the whole code, but this is what I see when compiling your code after fixing a few weaknesses.
Thanks for looking. I double checked the adapter instantiation and connections and seems to me is all right. I can’t find any errors. Thanks for your support.
I had a deeper look to your code. You are constructing 2 objects of your RAL model, 1 in your env and the other one in your base test. You have to have only 1 object of your RAL model.
I was uploading to the github a running examplse. It has still a few weaknesses.
Thanks a lot, i’ll try to understand my mistake. If you can pull request your code i’ll appreciate, thanks a lot for the help.
I’m not so famliar with the github. If you cannot see my solution please respond on my email christoph@christoph-suehnel.de. Then I’ll respond with a zip-file.
I’m not so familiar with the GitHub. If you cannot see my solution please respond on my email christoph@christoph-suehnel.de. Then I’ll respond with a zip-file.
Thanks for your support. I updated the code on Github and added your name as a contributor. I understand my mistake. I passed the handle of my model on the test class and created another on the env class and other minor mistakes.
Thanks a lot.
can you send the example of this i am facing same issue
In reply to tinku_mistry:
Please share an edalink with your tb code .
