I am new to modelsim DPI.
Could you recommend book or documents to study easy modelsim DPI?
Thanks a lot !!!
Thanks a lot !!!
The DPI is part of the IEEE 1800-2012 standard, which you can get for free here. I am not aware of any other books that cover this topic, but there are a number of on-line sites if you search for the SystemVerilog DPI. There are a few examples of the DPI in the directory that comes with ModeslSim.
Thank you for your kind answer.
To speak frankly, I don’t know how to compile the examples of the DPI in modelsim installed folder. In example folder,there are some files,which are related with them.
Step by Step, I want to know how to compile DPI files, which are coded as imported function/task, and exported function/task.(There is no full source code in IEEE 1800.
There is few imported function / task and exported function /task examples in Web.
In reply to draco:
Attached is a complete example with imports and export.
DPIExport.tar.gz (16.2 KB)
The book SystemVerilog for Verification has a complete chapter on DPI, building up examples from scratch. Make sure you get the 3rd edition, in red, for the best examples.
Cheers,
Chris
Thanks a lot…
In reply to chrisspear:
Thank you very much for your recommendation book.
I read the recommended book and have to study more deeply.
I think that systemverilog is more difficult than verilog.
I want to have more easy and detailed book for a beginner.
Thanks again and again.
